Introduction: 3D Printed Light Switch Guard
Picture of 3D Printed Light Switch Guard
The goal of this ible is to show you how to make a 3D printed light switch guard so that you can't accidentally flip a switch. This is useful in home automation scenarios with smart bulbs, retrofitted circuits (I had a light switch for my garage that now powers my garage door opener), and more.
These should cost you about 10c each instead of the outrageous 8$ local suppliers ask (or 1$ + 8 weeks of waiting for it to arrive from overseas).
Step 1: Materials
Picture of Materials
You can probably use a 3D printer from your local library if you don't have one. As for filament, since making my guards (which look a bit dirty around the bend because I had freshly switch from black PLA to white PLA), I have since discovered PETG white fillament which is slightly closer in look to the white glossy finish of industrially moulded pieces.
Lastly, you can use the files with the design I made. The STL file is ready to use for printing, and I included my SKP file if you want to edit it in sketchup.
Step 2: Print and Clean
Print it in the orientation it is in now, using added supports. Whenever I make screw holes in my models, I always clean them up after the print by using a drill bit of the size needed, but spinning in reverse, this means that the heat just smooths out the hole, preventing snags and tears.
Step 3: Use It
Picture of Use It
The cut-out corners mean that you can still flip the switch if you need to, but there will be no more accidental knocking of the switch.
About This Instructable
412views
3favorites
License:
Bio: www.patreon.com/making https://www.youtube.com/making www.thingiverse.com/MakinThings/designs
More by MakinThings:DIY Musical Xmas Lights for Beginners with raspberry pi3D Printer PCB EtchingTurn your 3D printer into a plotter
Add instructable to:
