3D Printed Mini Jambox Bike Mount
7,985
80
6
Posted
Introduction: 3D Printed Mini Jambox Bike Mount
Gadget Hacking and Accessories Contest
Second Prize in the
I picked up a Mini Jambox for some super portable music to carry around my apartment, but that only lasted so long. Soon I wanted to take it with me on long bike rides. That's right, it was getting serious and I was ready to make a more devoted connection. So I designed a bracket, printed it up at Shapeways, and now we're inseparable. You can't stop us, but if you want one of your own, here's how to do it.
Update: Here's how it installs and gets removed. Installation is faster with two hands, but I needed one for the camera. I wanted the mount to be quick for this so there's never any excuse to leave the Mini Jambox on the bike.
Step 1: Design the Mount - Hold on to That Frame!
The Jambox needs to have a good grip on the bike frame. This means that you want friction and compression. In other words, it should stay in place and not twist. Stay strong. To do this I'm going to use some rubber between the mount and the frame. This material is easy to get, just use an old bike tube.
The main pieces of the bracket here are the same: a piece of pipe cut lengthwise with tabs coming off the sides. One of them has a hexagonal shape to keep the nut in place.
The wall thickness here is 3mm and this is made for a 26mm stem.
Step 2: Design the Mount - Hold on to That Jambox!
This part of the mount is pretty basic. There are two pieces that wrap around half of the speaker and they're connected by another piece in the middle. Be sure to provide enough room between the two arms so that the controls aren't covered.
In addition to the two arms there are small pieces that stick up on the top and bottom. These are to hold a rubber band in place.
Step 3: Design the Mount - Connect It and Reinforce It!
To bring it all together, move the jambox mount to one of the bike mount pieces. We want to save space and printing cost and build up strength so the closer the better.
Now that they're connected I added a couple ribs on each side for more strength. Bike handlebars get a lot of jolting so strength is important.
Step 4: Print It and Get a Couple More Things
I printed these pieces with Shapeways. The file is attached here. The total cost was $40.
In addition to the fancy pants 3D printed parts I also used:
  • old bike tube
  • hot glue gun
  • M4 screws and nuts
  • rubber bands
Step 5: Glue Gun for Grip
To give the bike mount some grip I applied thin lines of glue from a hot glue gun to each arm. Sorry for the crappy picture here, but if you look reeeeaaallly closely you'll see a lighter shade of white on the other white piece. I promise, it's there and it helps a lot.
Step 6: Clamp on the Bike and Insert Jambox
Now that you're ready to go, installation is straightforward. Here we go!
  1. Wrap piece of tube around stem
  2. Screw pieces of bracket together
  3. Insert Jambox Mini
  4. Put on rubber bands
  5. Ride like the wind with the soundtrack of your awesome and amazing life surrounding you
  6. Scream
  7. Shout
  8. Enjoy it like it's your last day and damn it's good to be alive
  9. Smile at everyone you see
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    6 Comments
    this is exactly what i was looking for. I hate biking with head phones. thank you for the idea.
    This is rad, you should put it for sale on Shapeways too.
    Cheers
    Nice clean design! I like how you made it easy to get it on and off the bike :)
