Introduction: 3D Printed Personal QR Code Necklace
Picture of 3D Printed Personal QR Code Necklace
Want to make a personal item of jewellery? Something unique? Why not make a 3D printed QR code for your favorite website, which can be scanned to allow people you meet on the street to find your blog or desired site, for a very expressive and individual item of jewellery.
This can be made in to a keyring, necklace, earrings or anything else you can imagine. It is fairly simple, involving only 4 main steps to achieve the final product. It does require a 3D design package, but several are available free online and are very simple to install and use. If you don't own your own 3D printer then locating one is fairly easy, as most universities have 3D printers available for the public use and staff are normally more than happy to guide you through using it. If not, then there are other tech groups, for example Hacker Space groups, which have 3D printers they are happy for people to use and help you with your project.
Step 1:
Picture of
The first step is to generate a QR code. There are several free websites that can do this for you, I used www.qrstuff.com. If you want something even more personal, like specific shapes or logos within the QR code, then there are programs you can download to do this.
Simply input the desired web address in to the QR generating website and then download the QR code it generates. Now is a good time to check that the code correctly redirects where you expect, so use your QR code reader on your phone to see if it redirects correctly.
Step 2:
Picture of
The next step would be to upload the QR code in to a 3D design program or software. There are a variety of 3D design packages out there, I used SketchUp and downloaded the basic package for free.
Once you have uploaded the QR code image you need to draw around all of the black shapes in order to separate them from the background, to allow you to pull the background to a different depth, making it 3D. (the programs simply sees this image as a flat object, like a piece of paper or a photo, and won't recognize the shapes on it, so you need to outline each of the shapes so they can be pulled to a different depth)
Adjust the scale to give it the desired dimensions. Also, it is important to take in to considerations the size and accuracy of the 3D printer you will be using, as some custom built machines may have trouble with fine detail. Once you have adjusted the scale for height and width, pull up the background to the desired depth. (I went with 25mm square and 4mm deep).
If you know how to program and are familiar with Python then there is a script you can download and run that will outline the black and white images within the QR code and you can just scale it to the desired dimensions.
In order to convert the file you have created in to a format that the 3D printer can use it needs converting to G code and exporting (this tends to be the type of file 3D printers generally use, but their are other formats, so it might be worth checking what file type the 3D printer you plan to use accepts).
Step 3:
Picture of
Save the G code file on to a SD card (these are generally the same card you would have in your digital camera and most 3D printers tend to have a slot for a SD card rather than a USB slot).
Insert the SD card in to the 3D printer and run the file. Make sure that the surface it is printing on to is clean and level, check that the distance of the nozzle from the plate is also correct, as the fine detail of the print might be dragged or damaged if the setting are not right. Allow the print to finish and the surface to cool before attempting to handle the print. At around 65 degrees Celsius the print will probably pop off the surface, but if not then a small tap from a chisel is normally sufficient. (For a print around 25mm square and 4mm deep it took roughly 90min to complete printing and used roughly 50cm of raw plastic).
Step 4:
Picture of
Once your design had printed then simply finish off by filing any rough edges with a small file, check that there is not any threads of plastic remaining inside the print, these can be removed using a pair of tweezers and gently file the surfaces for a nice finish.
Add contrast to the print by one of a variety of different methods, depending on what finish you want. You can simply colour the top surface in black with a permanent marker pen, or for a nicer finish you could infill the 3d sections with coloured latex or resin.
Use your QR code reader to check that the QR code redirects to the desired website. (QR codes tend to be pretty flexible and readers are able to still detect the desired site even if the code is not exactly correct, so you shouldn't have a problem getting the reader to recognize the code as long as there is sufficient contrast between the two colours you chose).
If you left a hole through the design then simply thread through the chain of a necklace, or you can use a small drill to produce a hole and then attach it using a small metal ring.
Enjoy your new necklace!
Step 5:
Picture of
Not limited to use as a necklace, you can use it as a key charm and anything else you think of!
elementslab.net (author)2015-11-16
https://www.facebook.com/509690035788229/photos/a....
Here's another example we make a 3D printed QR code worked. What a magic!!
alain.messin.pol (author)2015-02-06
I think it may be very useful indeed; I did something like that, but bypassing the boring sketchup step. I generate openscad code directly from the website, using php class qrcode and a little php code. So that you only need to export to stl to proceed printing. But as I have only access to one colour 3d printer, I print the white code only.
But I would like to know how you suceed to fill hollows with resin or latex to improve contrast.
Jack Rodgers (author)2014-10-12
Some 3D barcodes can hold 4000 to 8000 characters. Most IOS devices can scan these barcodes and show the text they encode, or use an app for that.
This idea would be great for selfi ids for pets, children, etc.
About This Instructable
8,154views
14favorites
License:
More by GeneticCuckoo:Resident Evil T-Virus and Antivirus necklace3D Printed Personal QR Code Necklace
Add instructable to:
