Introduction: 3D Printed "Print-In-Place" Adjustable Wrench
Picture of 3D Printed "Print-In-Place" Adjustable Wrench
Print-in-place 3D printing means that several coinciding parts are printed at the same time. This is a experiment from 2013 when i did some tests using this technique in my desktop 3dprinter at home. The objective was to create a adjustable wrench that would have all the parts done in one print and assembled once the print was done.
I´m sure there are lot´s of different takes on a wrench like this and maybe better ones at that, this is only my take at this.
Step 1: Download the File(s)
There are a few versions to download. The original size was done with ABS in mind. When i print this in PLA i scale it up to 150% to get a slightly bigger gap between parts and that usually works fine for me.
All files are available on Thingiverse aswell as other sites.
Step 2: Slice and 3D Print
Picture of Slice and 3D Print
I have sliced this in a few slicers and none have shown any signs of problems with standard settings.
I usually print it at 0.2mm layerheight with the recommended settings for the material i use. If you print this in PLA i recommend that you scale it up to around 150%.
Step 3: Remove Support and Loosen Parts
Picture of Remove Support and Loosen Parts
If your lucky the support structures can be removed by hand without to much effort but if your unlucky all the parts may have fused together and your stuck with a non-adjustable wrench.
If your having problems removing the support structures and loosen the internal part you can try to use a tool to do so.
Once the support parts are gone and parts a moving you can add some olive oil to the moving parts to make them move smoother if needed.
Step 4: Share Your 3D Printed Wrench With the World
Picture of Share Your 3D Printed Wrench With the World
Congratulations, you made it!
And while it may not be the easiest print i think it´s ok share your wrench with the world, post a make or just post some pictures of your latest 3dprint.
This can be a fun experiment and a great project to showcase what you can do with a standard desktop 3D printer.
About This Instructable
2,414views
54favorites
License:
Bio: Award-winning Swedish 3D designer and 3D Printing evangelist. Author of The OpenR/C Project and The OpenRailway Project.
More by Daniel Norée:3D Printed "Print-In-Place" Adjustable Wrench The 3DPrinted "Furry Vase"3D Printed 1:10 OpenRC Formula 1 car
Add instructable to:
