loading
Step 3: First Tests
First I prepared some test files to print to get an idea of what is possible with the printer and optimize the dimensions of the grooves.  These record files have circular grooves on them containing sine waves of various frequencies, amplitudes, groove depths, groove widths, and beveled groove edges.  (When I say that the groove "contained" a sine wave, I mean the bottom of the groves moves up and down in a sinusoidal pattern around the record).  I generated all of these files in Processing using the ModelBuilder library to export straight to STL.
TEST ONE:
My first test record had 72 grooves on it, screen shots of the model are shown in figs 2 through 6  I tested two frequencies of sine waves:
1000 cycles per revolution = 555Hz at 33RPM
500 cycles per revolution = 277Hz at 33RPM
I tested a few different amplitudes, depths, and groove widths for these frequencies and gave each groove a constant bevel size of 2px on each side (you can see in fig 5 how the edges of the groove flare outward).  I printed the record in Objet's Vero Clear material, this material is a fairly hard, clear resin.  I printed the file with the "smooth" setting to prevent any support material from being deposited in the grooves.  Unfortunately, when I was ready to make this print we were having some problems with power in our shop, so I had to use another Objet machine that was not set up for high resolution printing; the best I could do was 300DPI X/Y resolution with 30um Z steps.  This is half the resolution that each of these axes is capable of, meaning the print came out at (1/2)3, or 1/8th resolution overall.  The results are shown in the video below (the grooves were not deep enough to keep the needle inside, so I had to hold in it place with my hand).  The record was also a little big for my record player, I decreased the diameter of my STL file to 11.8" in later versions.
In this video you can hear a periodic frequency sweep on top of the steady sine wave (best heard w headphones).  This sweeping sound is caused by the needle moving over the thousands of tiny parallel bumps in the print caused by adjacent print-heads on the Objet machine.  This noise is unavoidable, but increasing the strength of the signal will help to make it less noticeable.
The Processing sketch that generated this record is given below:
TEST TWO:
In my next test I made a record with 108 grooves, still sine waves, but this time I made the grooves deeper, increase the bevel of each groove to equal half the amplitude of the sine wave, and tried out three different frequencies: 555hz, 277hz, and 139hz (1000, 500, and 250 cycles per revolution at 33.3rpm).  I also tested different amplitudes (4, 8 and 16 steps), groove depths (2, and 3 steps below the top of the record), and groove widths (1, 2 and 3 pixels).  Since our shop came back online, I switched printers and started printing with Objet's Vero White material, which is similar to Vero Clear in texture, but (as you might image) is a translucent white color.  This time I was finally able to print with the full 16 micron and 600 dpi resolution of the printer.  Here is a video of the results:
TEST THREE:
In my third test I increased the resolution of my stl file to test out some higher frequency sine waves.  I used 22000 points per revolution to draw out the sine waves (as opposed to 10000 in my previous tests), this puts me at about the max resolution I can get with 600dpi (calculated in the last step).  I tested three frequencies: 1110hz, 832hz, and 694hz (2000, 1500, and 1250 cycles per revolution at 33.3rpm).  I also tested different amplitudes (12 and 16 steps) and groove widths (2 and 3 px).  Here is the video:
RESULTS:
At the end of all these tests I learned a few things about 3d printing records with the Objet:
Groove Depth min of 48um below top of record - I found that grooves that kept the waveform at a minimum of 48um (or 3 16 micron steps) below the top of the record kept the needle in place while being played.  This was true for all the frequencies I tested.
Groove Width 2px - At lower frequencies I found that the 2px grooves were much less noisy than the 1px, but I didn't hear too much of a difference between 2 and 3px.  However, when I tested again with the higher frequencies (2000 cycles/rev) I could hear much more noise on the 3px groove than the 2px.
Frequency Range - at 22000 points per revolution, I easily achieved the upper limit of the human vocal range (about 1.1kHz).  Theoretically I should be able to reproduce frequencies equal to half my sampling rate.  With a sampling rate of 12kHz (calculated in the last step), the highest frequency I can theoretically achieve is 6kHz.  I suspect that the movement of the liquid resin during the curing process will prevent me from actually achieving these frequencies, but if I can just get into the 2kHz range it will still sound reasonably good.  Based on the tests I've run so far, I think this is possible.
Dimensions - Although it seems like a 12" record should measure 12" in diameter, I found that printing at 12" made the record slightly too large for my record player.  I decreased the diameter down to 11.8" and it worked great.
Max file size of ~300MB - Although Processing is capable of producing much larger files, the Objet Software that runs the printers seems to only handle about 300MB of data at a time.   It's possible that increased RAM might bring this up to 500mb, but this still does not give me a lot of room to work with.  Although this is plenty for normal CAD purposes, I found out that I would have to be very efficient with the way I packed data onto the STL for the final version of my Processing sketch.  One problem with my current sketch is that is has a constant angular sampling rate, this means that the same amount of data is used to describe a groove on the outer edge of the record and a groove near the center of the record.  Since the groove at the center of the record is much smaller it would a higher resolution than the outer groove, unfortunately, this extra precision goes to waste because the printer has constant DPI across the entire surface of the record.  Eventually, I hope to decrease the angular sampling rate of the inner grooves to save storage space and pack as much audio into the STL file as possible.
<p>I received an email today from someone asking me about how far I managed to go with replicating Amanda's process, so I thought I'd share my experience in more details. </p><p>Note that this experience below occurred in December 2014.</p><p>My goal was to try print a 3mn song on 1 side of a 12 inches vinyl and see what is the best quality and output I could achieve, noticing that it has been already more than 2 years since Amanda did her project, so I assumed that the technology would have progressed rapidly.</p><p>Amanda's instructions and provided programs help you generate the binary file, then create a 3D model (STL file) for a one sided vinyl with that song on it (eq'd specifically for vinyl previously as per the video). At this stage, I don't know if you can even generate a two sided vinyl STL model but this didn't matter to me for that experience. </p><p>I downsampled the file to 12hz as per her initial instructions and default settings. The outcome was a file that was 700MB. Generating this file alone requires HUGE amount of processing power. Note that I'm using a Mac Book Pro with 16GB of ram, solid state drive and a very powerful processor. It was nevertheless a painful process for the computer to generate the file. See attached an image of the model. You'll note that the entire surface is not covered, which I couldn't quite figure out why. I assumed that if it did take the entire width, the grooves would be a be bigger and therefore more tolerant to the level of precision currently available via 3D printing.</p><p>I then tried changing the downsampling rate to something higher (I started at 24hz), so I could get to a quality closer to what I'm after (i.e. that can be released). It looked something like this:</p><p>Unfortunately, the file couldn't even get generated. My computer would hang permanently. That wasn't even trying 44hz which is what I was ideally after...</p><p>To note: the output STL file had dimensions for X and Y initially rendering in mm instead of inches for some reason so something to keep an eye out on if you try that technique using Amanda's program (unless it had to do with the program I used to render the shape - I then had to update the dimensions manually to the equivalent in mm).</p><p>I stuck to my 12hz downsampling rate then and contacted the most advanced 3D printing company in Melbourne I could find (3Dsystems.com). They had by very far the best machines I could find on the market for once off printing. I figured this would provide me already with a significant improvement of quality from what Amanda had produced.</p><p>The machine used was SLA Flex Printer with XHD 0.050 mm layers. Resolutions were uniform on all 3 axis, XYZ with all parts having an accuracy of 0.001 &ndash; 0.002 inch per inch of part dimension. This was by far the best printer I could find. The material used was 'Accura Xtreme'.</p><p>Unfortunately, the machine and vinyl would break before it could be fully printed, the file being far too large. Files are generraly a few dozens MB at most, and Amanda herself mentions that 300MB is already pushing it. </p><p>Doing some further research, I then thought that the model may be using a lot of polygons which are not required to print all the details. I therefore asked Amanda if she thought we could use a technique called decimation to remove useless polygons and therefore make the file lighter, but she confirmed that the program she created was pretty efficient. Considering how precise vinyls are in terms of geometry, this makes perfect sense. <br></p><div>Note that the price quoted to me was about US$250 for 1 copy (price goes down obviously as you order more). Copy of the quote attached.</div><div><p>As of today, there therefore doesn't seem to be a way to print even one single song in a decent quality. The song I used was just below 3mn and in mp3 format.</p><p>I'm not sure whether there are elements I could have tweaked to change the output (type of printer or material used, settings in the file), but it seemed that as of early 2015, we were still a long way to being able to 3D print vinyls from the comfort of our home, or as an alternative manufacturing process to the vinyl plants (which was the main goal of my investigation here). </p><p>If anyone has tried similar experiences and maybe had better outcomes, I'd love to hear about it.</p><p>Cheers, Charly</p></div>
<p>thanks</p>
<p>Phew! Don't give up! I managed to get it to work after some trial and error and re-reading the instructions. Most of my problems came about from using different versions of Windows. I found I could only get it to work on my desktop, not my laptop.</p>
<p>thanks for posting this, lots of good info here.</p>
<p>Hello Amanda!</p><p>I represent a national touring band that wants to talk with you about your 3D printed vinyl concept. They want to release plans for people to print a new song for record store day. I'd love to have a quick chat about how feasible this may be and if you'd ever be interested in working with us? Or perhaps recommending someone to work with as I'm sure you're very busy...All the best to you!</p><p>Vance Anderson<br>vanderson7@me.com</p>
<p>In<br>addition, this 3D printer has a dual extrusion having a closed environment. It includes a sliding door that simplyprovides you withaccess to your prints.<br> <br><a href="https://www.allthat3d.com/cheap-3d-printer/" rel="nofollow">Allthat3D.com/Cheap-3D-Printer/</a></p>
<p>Hello Amanda,</p><p>The vinyl 3D generate with record generator as somme error.</p><p>when i repair the STL with Slic3r there are a probleme of layer. How resolve this probleme and use the STL to gcode.</p><p>Do you have this probleme to print the STL?</p>
<p>Hello Amanda,</p><p>I resolve my probleme and i made it.</p><p>Could you tel me de good parameter for a rmp 33.3</p><p>I have take the following parametter an i have a little disque. 11.8 m x 11.8 m</p><p>rpm = 33.3;//rev per min<br>float secPerMin = 60;//seconds per minute<br>float rateDivisor = 4;//how much we are downsampling by<br>float theta;//angle variable<br>float thetaIter = (samplingRate*secPerMin)/(rateDivisor*rpm);//how many values of theta per cycle<br>float radius;//variable to calculate radius of grooves<br>float diameter = 11.8;//diameter of record in inches<br>float innerHole = 0.286;//diameter of center hole in inches<br>float innerRad = 2.35;//radius of innermost groove in inches<br>float outerRad = 5.75</p><p>many thanks.</p>
<p>draw record and groove geometry Looks awesome</p><p>Thanks in advance</p>
<p>Good project</p><p>I did not find the program or code to do the following (i download the processing 3 softwar):</p><p>- draw record and groove geometry</p><p>- export model in STL format (the link is break)</p><p>could you help me to made your project,</p><p> </p>
https://github.com/amandaghassaei/3DPrintedRecord
thank for your repy
<p>Dear Amanda,<br>Thanks for this brillant project.</p><p>Is there any way to use it as sort to get something more extruded, more like a sculpture?</p><p>I'm thinking about these prints made from different songs (http://www.realitat.com/microsonic/portishead.html)</p><p></p>
<p>Good post. I learn some thing tougher on distinct blogs everyday. Most commonly it really is stimulating to learn to read content material from other writers and exercise a specific thing there.</p><p><a href="http://enablerslove.tumblr.com/" rel="nofollow">http://enablerslove.tumblr.com/</a></p>
<p>First off, you've got bloody good taste in music. Thank you for not printing any Beatles tracks . . . that would be fine, but . . .</p><p>Next, I'm shocked you can hear anything at all printing this stuff. It's fascinating. Obviously the higher the frequency, the higher the resolution needed. Prints of older music containing less fidelity will naturally sound closer to what we're used to hearing, due to the lack of upper harmonics. </p><p>At any rate, what I'm really wondering here is, someone needs to write a new slicer, or whatever software, that can route the printer in circles. I clearly hear the &quot;sawing&quot; of the needle traversing the lines that are created by the printhead going at 90&ordm; angles all the time. Shouldn't we be trying to print this stuff in a spiral? Just a thought. The resolution requirements would actually be less if the material were deposited in a spiral. The resolution requirements of printing curves using only right angles is far beyond where we're at for now.</p><p>Thoughts?</p>
<p>This is incredible! I am trying to do this with my own music, however the 3d printer i have access to can only print an area 8in wide. I tried changing the processing code to reflect that and it failed. Any advice what needs to change to shrink the diameter of the 3d model? I really want to try this!</p>
<p>Thats exceptional...</p>
<p>Awesome! If you do a 7&quot; 45, both the resolution could be higher (pickup moves past more groves per time) and the files smaller/easier to generate, right? Experimented with any 45 rpms?</p>
<p>Ah, of course the quality is lower at 7&quot; than at the outer edges of a <br>12&quot; anyway. But still interested in your progress, if you ever did try <br>with RIAA eq, higher RPMs etc.</p>
<p>Ah, of course the quality is lower at 7&quot; than at the outer edges of a 12&quot; anyway. But still interested in your progress, if you ever did try with RIAA eq, higher RPMs etc.</p>
<p>I love learning new and interesting things ...<br> and this web is full of this.<br> Thank you very much for sharing knowledge and continue to do so</p>
Is this possible to make on Ultimaker? Can I make the vinyl 5&quot; and can I make muliple short tracks on it ? Sorry for all the questions but you got me all excited lol
<p>@Amanda Ghassaei</p><p>Hello. Have you ever considered to use GPU computing? That might be helpful for sound processing on my opinion.</p>
<p>Incredible. A little info off topic- as far as I know Kurt Cobain hated Nevermind, the album which contains Smells Like Teen Spirit. He hated this song even more. The reasons he stated: the album sounded too perfect and clean, much unlike Nirvana's first album. He felt they had sold out. I wonder what he would say if he heard how Smess like teen spirit sounds on this record. :D</p>
<p>Learned some cool things in this tutorial, thank you.</p>
<p>This is such a cool program! But I am having trouble running the processing sketch. It says</p><p>&quot;No library found for unlekker.util</p><p>No library found for unlekker.modelbuilder</p><p>No library found for ec.util</p><p>Libraries must be installed in a folder named 'libraries' inside the 'sketchbook' folder.&quot;</p><p>I tried putting the files in a bunch of different folders but non of them seemed to work. Any thoughts?</p>
<p>I have the same trouble! Any way to fix it?</p>
<p>the modelbuilder library isn't in the right folder.</p><p>this project uses the same library, see if following the instructions from the top comment helps you:</p><p>http://www.instructables.com/id/3D-Printed-Photograph/</p>
<p>this is simply amazing! I can't believe it's printed!</p>
<p>Hey guys,</p><p>I had an issue with the python script that kept sending me this error: IndexError: list index out of range</p><p>If you run into the same issue this fixed it:</p><p>Just add this line right below: for i in range(numframes):</p><p> if len(frameInt)&gt;=(4*i+1):</p><p>Cheers,</p><p>Leart</p>
<p>What a creative technology 3D printing. Btw, can I made iPhone with 3D printing machine?</p>
<p>Great</p>
<p>This is incredible. I'm impressed at how far 3D printing has gone. Someday most of our items will be 3d printed, I assume. What do you think?</p>
<p>Hi Amanda, I just sent you an e-mail regarding a film shoot inquiry. Can you please check your gmail and let me know what you think? Thank you~</p>
<p>Amazing!</p>
The problem seems to be in the nature of the printer output design. I think a much simpler solution would be to develop a printer that printed a long line for the audio then use a separate device that rolled it into a record like a really short but very thick jelly roll. I don't know if my idea makes sense but basically you'd be printing and then rolling a line of sound into a record format. I don't know of any type of printer that does this though or if one could even be made. It just seems that printing it all at once as a single object is where the problem with audio quality is coming from.
<p>Thank you for all what they offer</p>
<p>I have just showed this to my cousin and the reaction was ... @#!</p>
<p>deym!</p>
<p>Hi, Amanda, great project. Can you tell me how can i make a sound loop record?</p>
<p>Smells like teen spirit is a timeless song. And that record is so cool. Great job.</p>
<p>Excellent</p>
<p>I like your work </p>
<p>Hi, this is a really great tutorial but I ran into a problem when trying to find the &quot;wavtotxt&quot; file on Python. Since Python has updated I wondered if it had been removed or possibly i just couldn't find it. I would really like to know how you found it as I was hoping to use this as a part of a project.</p><p>Thanks</p>
About This Instructable
378,508views
865favorites
License:
Bio: I'm a grad student at the Center for Bits and Atoms at MIT Media Lab. Before that I worked at Instructables, writing code for ... More »
More by amandaghassaei:OTCA Metapixel - Conway's Game of Life "9 Degrees of Freedom" IMU Twitter Controlled Pet Feeder
Add instructable to:
