3D-Printed Speakers
Introduction: 3D-Printed Speakers
Upgrade your desk with these modular 3D-printed speakers! While the rest of the office jams with their plain black and silver sound cubes, you'll be listening in style from your very own custom set. With only a handful of simple parts, you'll be able assemble or tear down these speakers in minutes. There's no need for a fancy, high-end 3D printer to make these, just a simple desktop model and a handful of dowel rods and you're nearly there.
Step 1: Parts and Materials
(2x) speaker (RadioShack #: 55076557) web only and sold in pairs
amplifier (RadioShack #: 55065111) web only
stereo to dual phono cable (RadioShack #: 42-494)
3D printer filament (RadioShack #: 277-237)
20' x 1/4" square dowel rod
(16x) M3 x 20mm screw
(16x) M3 lock nut
Step 2: Design Overview
Like many of my hardware projects, I created a reasonably detailed 3D model to help work out my design. I wanted the case to work for multiple speaker sizes, so I settled on a modular design vaguely inspired by space frame supports. After measuring and modeling the speaker I had chosen, I began to sketch out different joints that could accommodate different speakers. Using dowel rods as the support structure, I was able to create a design that could easily be extended. I'm satisfied with the "hollow" design, despite it lacking the resonance that enclosed speaker cases use to naturally amplify sound.
Step 3: Assembly: Print Parts
Each speaker consists of 21 individual printed parts. These are as follows:
(8x) corner sockets
(5x) cross brace sockets
(4x) speaker clip bases
(4x) speaker clip tops
We'll need a set for each speaker, so send it on over to your 3D printer before bed and you should have a set by the time you wake up!
Step 4: Assembly: Prepare Dowels
For each speaker we'll also need to cut the dowels for the frame. This particular design is based around quarter inch square rods. Measure and cut the following per speaker:
(12x) 3.375 inch edge rods
(20x) 3.125 inch cross rods
(4x) 1 inch speaker clip rods
Step 5: Assembly: Building the Frame
Grab the 3D joints and your bundle of cut down dowel rods and lay them on a flat surface.
Lay out four 3D corners and with four edge pieces, four cross brace pieces, and a 3D cross brace in the middle.
Slide two edge pieces and a cross brace piece into the bottom slots of two 3D printed corners.
Slide two more cross brace pieces into the 3D cross brace.
Slide the two remaining 3D corners into the assemblies to complete the back face.
Stick four edge pieces into the the vertical holes of the 3D corners.
Create four cross brace assemblies with the remaining 3D cross brace pieces and rods.
Pop the the cross brace assemblies into the 45° holes in the back face assembly. You'll need to bend the rods slightly to make them fit.
Create a square face assembly with the remaining 3D corners and edge rods.
Place the square assembly onto the previous assembly one corner at a time, this will require more bending, but everything should snap into place.
Pop the four mini rods into the 45° holes in the open face.
Slide the bottom clip pieces onto the mini rods.
Step 6: Assembly: Mount Speaker
Lay the speaker over the clips along the edge.
Take the clip tops and slide the machine screws through each.
Slide the clip tops over the speaker and tighten until the speaker is snugly fastened.
Step 7: Assembly: Wire Electronics
Slide the quick connect clips of the amplifier onto the proper tabs of the speakers.
Pop the speaker connection (Green and Grey wires) into the amplifier.
Clip and strip the power connector from the wall power supply.
Solder the red and orange (control wire) to the positive output of the power supply.
Solder the amplifier black wire to the negative output of the power supply.
Plug in the dual phono to stereo cable to the amplifier.
Step 8: Enjoy
Your speakers are all ready to go! Plug in to your music player of choice and relax in satisfaction with your new 3D-printed speakers.
    • Epilog Challenge 9
      Epilog Challenge 9
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    A speaker without box loses up to 75% power.
    An unboxed, unbaffled speaker loses nearly all the bass. A speaker run without a box will also hit the limits of travel on the bass notes and be damaged at what may seem like modest volume levels.
    I could live with the efficiency loss but not the acoustic tragedy, or the pain in cleaning dust off, or that it will probably rattle itself apart if used for more than moderate volume levels.
    Overall it's a great example of "just because you can do something that doesn't necessarily make it a good idea."
    I'm aware. This is a decorative case.
    Repeat after me, form follows function.
    also encase the back of the speaker in pvc tube or cap packed with insulation and sealed with silicone and base will come back along with form
    makes an excellent frame for an underwater synchro speaker
    Look great and thanks for sharing. Disregard the crybabies it was obvious to anyone with a brain that these would not have great sound quality. yet people think they need to point out the obvious. I am going to turn this into a class project
