Introduction: 3D Printed USB Hanger Hook
Spring cleaning time!
I don't know about you, but some days my desk is just an absolute disaster... Here's a simple pocket sized solution I came up with to tidy up my desk and keep some commonly used items at arms reach.
Quick overview of the design features -
- The body of the part has a slot so it will flex to accommodate a wider range of USB overmold styles.
- The hook part is angled slightly inward to account a few degrees of droop/sag. This was done to account for USB plugs that may be a little loose.
- The hook section is also split in the middle so it can be used to keep a cable tidy, store an SD card, or hang something like a key ring.
Lets keep this instructable quick and simple - onto the next step!
Step 1: Tools, Materials and Digital Data
Tools needed:
1. 3D printer or access to a 3D printer
If you don't have a 3D printer you can get a copy of this hook from my website here: USB HANGER HOOK
Also, if you're curious, this is the Amazon link to the 3D printer I used to create this hook: FlashForge 3D Printer (affiliate link)
Materials needed:
1. 3D printer filament
Specifically, this is the exact filament I used: SAINSMART TPU (affiliate link)
I recommend using TPU or similar flexible filament. PLA and other materials will work but can be more difficult to slide over the USB plug. I used 100% infill, you could get away with less.
Data needed:
1. Grab the .STL file attached to this step
This is a quick print that doesn't require any supports or raft.
*If you'd like to get more info on how to get started 3D printing or what settings are best for different materials, Instructables has a great 3D printing class, checkout this link for more info:
https://www.instructables.com/classes/tagged/3d-printing/
*Note: My posts may contain affiliate links to products I use and feel comfortable sharing. Which means when you click the marked product links in my post nothing changes on your end, and I earn a small % on qualifying purchases. Thank you for your support!*
Step 2: Assembly
You've probably already skipped ahead. I don't blame you, I likely would have done the same thing...
You probably already did this too, but just in case - slide the hook onto your USB plug and plug it into your USB port. Start hanging stuff.
Yep, that's it. All done!
Step 3: Redundant Step?!
Perhaps, but here we are. Time to hang out!
This USB hook easily fits my bluetooth headphones, a small tape measure (affiliate links) and is also a perfect home for the other end of the USB charging cable I have plugged into my monitor.
So yeah, that's all I've got for this one, time to wrap it up.
I hope you liked my little pocket sized USB Hook and if this helped your springtime desk cleaning, please consider voting for me in the Pocket Sized contest.
_____
If you'd like to see what I'm up to when I'm not Instructable-ing you can find me at these places:
My Website: https://www.makerneer.com/blog
Instagram: https://www.instagram.com/makerneer
Facebook: https://www.facebook.com/Makerneer
Note: This post contains affiliate links.
