3D Printed Wine Bottle Carousel
228
8
Posted in HomeDecorating
Introduction: 3D Printed Wine Bottle Carousel
About: Designer/Maker using 3D printing to create awesome products. Check out my website for more 3D printing builds or downloadable STL files.
This build is a complement to the Wine Glass Shelf build, you can see that here. This build is almost completely 3D printed with the exception of one hardware piece. With a simple finish and assembly, you can enjoy a rotating wine bottle carousel.
Step 1: ​What You Will Need
Materials:
3D Printed Carousel
3D Printed Base
Lazy Susan Turntable Bearing
Primer
Bronze Spray Paint
Clear Coat
Glue
Sanding Paper
Tools:
Orbital Sander (optional)
Any/all necessary protective equipment.
***Links provided are affiliate links if used to purchase something may provide Adylinn Studio a small commission.
Step 2: 3D Printed Parts
The print time for the carousel is quite extensive at its current design so I would not feel comfortable recommending 3D Hubs since the cost would likely be too high to justify.
For those of you who do have a 3D printer, I recommend the following settings:
Carousel (decent surface quality to limit amount of sanding needed)
Filament choice not really important
0.2mm layer height
25-30% infill
Support required
Raft recommended due to minimal surface contact
Base
0.2mm or higher layer height
15-20% infill
No Support
Brim optional
Step 3: Finishing 3D Prints
  • Remove raft and support material.
  • Sand carousel to the desired smoothness. Start with 220 or 320 grit and move up until you have a nice smooth part without visible print lines.
  • Wipe the sanded parts with a lightly damp cloth or paper towel.
  • Apply even and light coat of primer.
  • Allow enough time for primer to dry, then sand lightly.
  • Once the parts are dry, evenly apply light coat(s) of bronze spray paint.
  • Once the parts are dry, evenly apply light coat(s) of clear coat.
I will sometimes use a healthy amount of spot putty to help with print lines on parts that are difficult to sand. I will typically do this after the final sanding and before the primer.
Step 4: Assembly
  • Glue the turntable bearing onto the carousel and base respectively. Alternatively, you can fasten the bearing with screws.
  • Insert wine bottles and enjoy your Wine Bottle Carousel!
Step 5: Wrap-up
Thanks for checking out the Wine Bottle Carousel 3D Printed build! If you enjoyed it, I post monthly builds using 3D printing on my website, https://www.adylinn.com/builds/.
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
