Here is what I have found works with tissue paper.
When it comes to printing plastic on tissue paper, the most important thing to do is keep the paper flat and wrinkle-free during the first few layers and stationary all the way through the build process. Spray-on adhesive can't be used directly on the build surface because the paper will tear when you try to remove it at the end.
The only method I have found that works consistently is to construct a frame that sits snuggly around the build platform, flush with the surface, and glue the tissue paper to it around the perimeter.
This Instructable details how to go about building your own frame.
Source file for the PaperFly I printed in this example are at http://www.thingiverse.com/thing:32845
Step 1: Graph your build platform long edge
Only one pair of parallel edges need to be a tight fit around the build platform to keep the frame stationary. In my case with a MakerBot Replicator it is easiest to make those the left-right pair of edges; the rear is complicated by the heated build platform cabling.
Mark off both side-edges of the build platform, making sure they are either precise or slightly smaller than the edge length of the build platform. If the frame is too tight after construction it is relatively easy to shave away material until it is a snug fit.
Step 2: Graph your build platform short edges and escapes
Draw the bounding box in the center of the graph paper and mark off any extra features you need to take note of. In my case that meant making a cut-out centered at the rear for the heated build platform cabling.
Step 3: Complete a C-shaped frame outline
Trace a thick border around the inner C-shaped line. This is the frame width you'll be cutting out and gluing tissue paper to.
In my case I'm using 1/4" square graph paper so you can see that a frame width of 3 squares (3/4") fit nicely on my page.
Step 4: Glue graph paper on box or particle board
My first prototype was constructed on scrap box board (aka cut up cardboard boxes), so I can confirm that it will work, however the box board won't last very long as it saturates with glue used to stick tissue paper on it.
In these picture I'm using particle board cut into 1' x 1' squares.
Caution: Be sure to follow any recommended safety instructions for the glue you choose to use. In my case with spray-on adhesive this involved applying it in a well ventilated area.
Step 5: Cut out frame; keep outline intact
Use a keyhole saw or something similar and keep your saw kerf inside the inner C-shape so that the frame's fit will stay tight around the build platform. You can shave off material at the end if the fit is too tight.
Note: You do not want to significantly damage the outline as you will be using this as a mask to apply glue to your tissue paper. Large cuts into the material make it difficult to apply glue cleanly.
Cautions:
- Take your time when using sharp and pointy tools.
- Drill onto a sacrificial surface, such as another piece of hard-board.
- Keep fingers out of the cutting zone when sawing.
- If using power tools, follow any recommended safety precautions.
Step 6: Trace and fill outline on second board
This is where you'll be taping down sheets of tissue paper for gluing to the frame.
Step 7: Center and tape tissue paper on glue board
Place the outline template over top and spray adhesive all around. You only care about the protected tissue paper so more glue is better, but not super-saturated to the point that the paper falls apart.
Step 8: Press C-frame firmly onto glue in outline
Step 9: Pry up outline and gently lift taped corners
Now that I'm using particle board, it seems to work quite well as I'm able to wipe it down after so it doesn't stay sticky.
Step 10: Slide C-frame over level build platform
The clamped tissue paper should be a nice snug fit with no movement in any direction. Make sure the paper is still flat and there are no wrinkles. If you see any wrinkles you may need to re-glue the paper to the frame before it will print without snags and tears.
The C-frame edges should be flush with the build platform surface. If it isn't, you may need to shave off some material or de-burr some edges until it is. Any protrusions from the surface can (and will) snag on the printer nozzle and tear the tissue paper so spend some time getting this right.
Caution: Use common sense when working around a heated build platform. If you have been printing immediately before trying this technique do not touch the platform directly with your fingers until you are confident that the temperature has dropped to safe levels.
Step 11: Print something
- PaperFly: http://www.thingiverse.com/thing:32845
- OSHW RepRap LED Lantern: http://www.thingiverse.com/thing:32927
Cautions:
- The nozzle is hot; do not touch it.
- When printing PLA on tissue paper, a heated build platform (HBP) is not necessary for it to stick. I explicitly run mine at 40C so that it is at a known temperature above ambient room temperature. If you have not created a custom slicing profile for PLA-on-paper printing you will have to hand edit your GCode to set the HBP to a temperature lower than the default which may be as high as 110C.
- When trying this process for the first time or a new/unknown paper product for the first time, keep a hand close to the power button. If your paper starts to "melt", stop the build process. Paper does not melt! Unknown plastic content which may release toxic byproducts does melt.
- Err on the side of caution. If something doesn't look or smell right, stop the build process and figure out what it is.
Visit Our Store »
Go Pro Today »
I need to keep the fabric surface in contact with the heated build platform so the fabric itself stays at the correct the temperature. None of the plastics get fluid enough to seep into the weave of the fabric without a little help from both the hot nozzle and the heated build surface.
Good luck with it then. Cheers!
I'll have to try a slingshot launch. If that works and the tail stays intact I'll see about capturing some video.
I need to rework the v-tail structure, but I've been holding off until I receive a little something I ordered from microflight.com: http://www.microflight.com/Online-Catalog/Radio-Systems/Deluxe-Starter-Set-2
I haven't tried wetting it between Step 7 and Step 8 to get it tighter on the frame. That sounds like an interesting+useful variation.
Keeping it simple was key. :-)
I can't take all the credit for the glider though. It's derived from someone else's CC-By-SA licensed design.
Details are at http://www.thingiverse.com/thing:32845
