3D Puppy or Kitten Cake
16,214
22
14
Published
Introduction: 3D Puppy or Kitten Cake
I got a call from the local Animal Rescue League a few months after we adopted our dog for a donation to their annual bake sale fund raiser. I wanted to do something different than the typical cookies, brownies, cupcakes etc... So, after a bit of brainstorming, this is what I came up with. These were a bit time consuming but fun to do none-the-less. I only made 8 and I only got them out of the van and they were gone. At least I got to keep the box! Each serves 2-3 people.
What you need:
Wilton Mini Ball pan
Wilton Mini Wonder Mold pan
2 batches buttercream icing (about 8-9 quarts)
2 cake mixes; prepared (you'll have extra if you only make 8)
Gel Icing colors of your choice (I used brown, black blue and pink)
Couple marshmallows
Bit of vegetable shortening
Powdered sugar
4"x4" Cardboard squares
Foil (to cover cardboards)
Piping bag or Ziploc bag
Wilton Tip # 233
Wlton Tip # 12
Wooden Skewers (approximately 4" long)
A well rested hand!
Step 1: Baking, Assembling & Decorating
1) Cover each cardboard with foil. Color 1 batch of buttercream the color you wish to make your puppies. I left half the batch white and colored the other half brown. Color a bit of buttercream black for the noses and eyes. Color a bit more buttercream the color you want to make the collars. I chose to make mine blue.
2) Bake 8 mini wonder mold cakes (bodies) and 16 mini ball cakes (2 halves make a head). Cool completely.
3) Cut the "humps"off of the bases of the mini wonder mold cakes. Save the trimmings as they become the haunches. Turn over and cut the top flat so the head doesn't bobble. I kept these bits and used them to fill out the paw areas.
4) Using a bit of buttercream, secure each mini wonder mold cake to the center of each of the foil covered cardboards. Place a bit of buttercream on the tops of the mini wonder molds to secure the heads.
5) Trim the mini balls so that they will sit flat against each other. Again save the trimmings. Sandwich 2 halves together with a bit of buttercream. These are the "heads".
6) Place the "heads" on top of the mini wonder molds and drive a skewer down through the top of the "heads" into the center of the "bodies" until you feel it hit the cardboard. There should only be about 1/4" of the skewer hanging out. Any more will need to be trimmed off. Scissors should be adequate here if they need trimmed.
7) Take the humps from the mini wonder molds and cut them in half. You should now have 2 half circles. Place one on each side of the form (rounded edge to the front) to create the haunches. Secure with a bit of buttercream. Take the mini ball trimmings and cut the edges off to make squares. Cut these into quarters. Place one quarter in front of each of the haunches and 2 in the front of the form to create front paws.
8) Using buttercream and a very soft touch, lightly ice the forms. You literally only need a thin coating of icing.
9) Using the #12 tip and colored buttercream, start about 2/3 of the way up the mini wonder mold and pipe a heavy line of icing to the bottom to create the front legs. Then using the #233 tip, colored buttercream icing and a the well rested arm, pipe on the fur. Start at the bottom and work your way up.
10) Using the #12 tip and icing, pipe an oval on each side of the head to make ears. Then pipe 2 dots on the front of the head about 2/3 of the way down to create the muzzle. Using white icing, pipe on 2 smallish ovals for the eyes. With the black icing, pipe on the nose, whisker dots and 2 dots for eyeballs.
11) Using the collar color choice, pipe a line around the neck to make the collar.
12) Take a bit of shortening and grease your hands. Take the marshmallows and knead them until they are soft. Mix them with a bit of powdered sugar to create a soft dough. Add a touch of pink gel icing color and knead thoroughly. Pinch off a small piece and form into the shape of a tongue. Stick onto the front of the muzzle.
Your puppy is now finished.
Step 2: Making a Kitten
The Kittens were made the following year. They are exactly the same as the puppies until the ears. Those are just built up triangles on top of the head instead of the ovals on the sides of the head. I also used fishing line to make whiskers and added an extra dot below the muzzle for the mouth.
    • Stick It! Contest
      Stick It! Contest
    • Backpack Challenge
      Backpack Challenge
    • BBQ Showdown Challenge
    14 Discussions
    Oh My Gosh!!! This is adorable!! I was looking for a cake to make for my sister's birthday and this is perfect! Thank you sooo much :)
    nice and I love the
    army form that they are in!!
    puppies and kittens will rule the world...
    Those are so cute!
    I love the fuzzy look you've created; you must have some steady hands. ;)
    Oh my gosh, the white kitty with the gray spots is so cute. Great instructable! At first, I thought it was just going to be using a cake mold or something, but this is really cool. I really like it!
    Thanks! That little guy was my favorite, too. I have a bunch of shaped pans, but, I never use them. Half the time I forget that they are here until after I've made the cake.
