3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
3D Triceratops Skull Sign
Back in June of 2007 I showed you how to make a 3D sign using the instructables logo.
http://www.instructables.com/id/3D-insructable-sign/
In this instructable I want to step it up a bit by making every element dimensional and textured
Step 1Cutting the parts
Cutting the parts
I used a high density urethane foam product made by Coastal Enterprises called Precision Board.
This material is 1 inch thick and has a density of 18lbs per cubic foot. They have material ranging from 6 to over 60 lbs pcf and in thicknesses 1/2" to 12" and over. However you could just as easily use the pink or blue insulation foam found at your local hardware or home improvement store.
This photo shows my paper patterns spray glued to the foam and my jig saw ready to rip, if you have a cnc router or maybe a LASER (this probably cant be cut with a laser but this is my submission for the epilog laser), this step could be automated, you work out the details here.
I have a jig saw and a dremel, so thats what I used.
You can draw right on the board or project a pattern or, like I did, set it up in coreldraw and print out on a plotter. You can even use your laserjet or inkjet and print and tape together your patterns, use your imagination.
4 comments
Apr 27, 2011. 5:37 PMpoofrabbit says:
This is really cool! I can see so many uses for the material and sculpture technique that you used. Thanks for then inspiration!
Feb 22, 2011. 4:57 PMJackie Peterman says:
This is such a great idea!! I am so fascinated by this. What would it cost me for you to make me a custom sign like this one? I'm thinking of zebras and fairies. Something that says, "I like fantasy but I also like black and white striped horses"
Feb 11, 2011. 9:22 PMChrysN says:
Nice!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:peterman921
