3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
3D board met Eagle3D
This is a Dutch version of this instructable.
In deze instructable leg ik uit hoe u met behulp van Eagle, Eagle3D en POV-Ray een 3D board maakt.
Step 1Programmas die u nodig heeft
Eagle
Met dit programma kunt u met behulp van een schematic een board file maken.
Eagle3D
Dit programma maakt van het board file een POV-File.
POV-Ray
Dit programma maakt van het POV-File een 3D board.
13 comments
Dec 6, 2010. 10:19 AMdunnos says:
Wow, best leuk om te zien dat er meer nederlanders op instructables zitten! Ik begon al te vrezen dat ik de enige was. :P
Aug 8, 2010. 9:01 PMdanger89 says:
Erg cool het werkt! It works! Ok I try to translate it into English: --------------- -STEP 1- You need 3 programs. Eagle itself to make your schematic & board design. Then you need to download/install Eagle3D. This download has 4 directories inside (but 2 important ones): -povray (the directory with the pov-ray libary files, you need that later to generate an 3D design) -ulp (this are files you need to great a pov file from a Eagle board design) --------------- -STEP 2- You need to start your Eagle open your design (*.brd) and select: File->Run... After that you select the 3d41.ulp file if your Eagle is up-to-date *otherwise you need to use 3d40.ulp for older versions*. This file you just download in step 1 (3d41.ulp file is in the ulp directory). Finally you select some settings if you want to and then you got a *.pov file in the working directory (project directory). --------------- -STEP 3- Now... you can generate a 3d image from this *.pov file! Download/install Pov-Ray, I'm using Linux, so the in command-line it will be: sudo povray +i your_project_name.pov library_path=/home/your_username/eagle3d/povray Library_Path=/home/your_username/.PlayOnLinux/fonts -geometry 1920x1080 NOTE: You can see you need to change "your_project_name" to your name you got for your pov file and "your_username" to your username under Linux. You will also notice that I just use the Windows Font Library of PlayOnLinux (WhineHQ could also work or you can just copy/past your /Windows/Fonts map to your Linux partition). --------------- -STEP 4- Eventually if you don't have any errors it will generate a *.PNG file (image file). It will be beautiful :D I add my image to this comment... I hope I helped people who did not understand.. :) Kind regards, Melroy van den Berg
Aug 8, 2010. 9:03 PMdanger89 says:
http://pastebin.ca/1913638
Mar 7, 2010. 3:48 PMaczez says:
Thanks,  Prima instructable.
Ga er meteen mee an de slag :)
Oct 9, 2009. 6:05 AMBlackice504 says:
Great Instructable
Tausend Dank!
PS to people so worried this is German Lang its not that hard yes its probley easyer for me as i learnt some German in school but anyway keep open mind people.
Oct 9, 2009. 1:19 PMme says:
It's not german, it is dutch
Dec 3, 2009. 8:10 AMeelco_g says:
What school did you go to ? lol
Dec 3, 2009. 9:29 AMme says:
 why would you ask? you're dutch to?
Oct 8, 2009. 5:07 AMmacobt says:
What is this,in English please.....
Oct 8, 2009. 11:49 AMJoe Martin says:
Please don't be ignorant, Instructables don't have to be in English.
If you want to know what is about use an online translator! =)
Oct 8, 2009. 5:48 AMScott_Tx says:
This looks like a job for babel fish.. http://translate.google.com/translate?hl=en&sl=nl&tl=en&u=http%3A%2F%2Fwww.instructables.com%2Fid%2F3D-board-met-Eagle3D%2F%3FALLSTEPS
Appears to be a way to make 3D renderings of circuit boards from schematics
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:berndeijg
