Introduction: 3D Cardstock Printing Without Printer
Can we print a 3D object with no 2D or 3D printer at all ? With no third party online service ?
Cheap ? And time consuming like if you build it from scratch ?
Maybe we can try at least :) Here is a solution for you ;)
We will need :
1. An internet connection with a computer or tablet
2. Slic3r software program
3. Cardstock like cereals box about 400 microns thick
4. A paper pencil
5. A paper sheet Glue
6. A lot of time :)
That is all folks ! Let's print something :)
Step 1: Download Your 3D Model
Modeling a 3D model is possible but not always really easy. Here we are going to use an online 3D object head
Step 2: Reduce and Slice Your 3D Model
Here you will need the software program Slic3r, to reduce and slice your 3D model.
To reduce :
- Press Add select head_with_eyes_rectificada.stl
- Then Object - Scale - Uniformly and 50 percent
- File save head_with_eyes_rectificada_50percent.stl
To slice :
- In Printer Settings - Nozzle diameter : 0.5
- Then File Slice To svg
- Choose head_with_eyes_rectificada_50percent.stl
- Then head_with_eyes_rectificada_50percent.svg
Step 3: Copy and Cut Each Slide
- Goto svgviewer
- Drag and drop head_with_eyes_rectificada_50percent.svg
- Copy each slice by transparacy with a pencil on a paper sheet
- Then glue the paper sheet on the cardstock
- Cut each slide following the pencil lines
Step 4: Glue Each Slide From Up to Down
- Here is the low tech 3D printer : a box of cereales ;)
- On the left corner is two slides one with six previous slides and the last one
- So then you add an other slide at the bottom
- You adjust on the corner the previous slide and the new one
- Glue the both together
- Then take the upper slide off
- And again with the next slide
- Go Go Go
Step 5: Admire Your Artwork :) or Not ;)
This is the end my friend :)
You can practice more with that better explanation than mine :)
Thank you for your time :)
