3D insructable sign
3D insructable sign
heres a step by step to constructing your own 3D sign with out a laser engraver/cutter
Step 1Patterns
patterns
the first step is making patterns. I downloaded the images of the logo by doing a screen capture
then traced them in coreldraw, but you could probably do this in most graphics programs or do it by hand and use a projector if you need to enlarge it. I then sent it to my plotter to draw the pattern on paper, again you could do this by hand also.
30 comments
Nov 23, 2010. 5:45 AMwareneutron says:
where it is found the examples?
Nov 23, 2010. 5:43 AMwareneutron says:
you use a printer?
Oct 17, 2009. 9:48 AMM4industries says:
Step zero: aquire a $7000 laser cutter.
Ive used a laser cutter before to etch my iPod. But that was at TechShop Durham in NC. About 400mi away from my house. Techshop was a side trip. But where else does one have acess to a laser cutter? Preferably an epilog.
Sep 18, 2009. 2:36 PMchrome123 says:
you forgot a word in the yellow box
Sep 18, 2009. 4:07 PMchrome123 says:
"Did you Dharma makes spray glue." >> ""Did you know Dharma makes spray glue?"
Apr 12, 2009. 4:22 AMrobots199 says:
I think with this same method, you could make the Left 4 Dead Hand On the Box. ( Runs to try it out ). Great Instructable.
Apr 11, 2009. 10:06 AMLastDevil says:
England mate, could use the info but i need a 16ft by 2ft sign and it would look great by somebody that knows what their doing ;)
Apr 12, 2009. 2:09 AMLastDevil says:
Thanks mate, PM sent
Feb 5, 2009. 4:42 PMsgt_rock says:
I L O V E the dharma initiative spray adhesive!!!!
Feb 11, 2009. 9:42 PMpoolgirlblue says:
your signs are beautiful.
Apr 11, 2009. 8:47 AMLastDevil says:
I need a shop sign but think it's 2 far to post and would cost a lot to send it :( Yaour great at what you do .... keep it up
Jan 16, 2009. 11:05 PMCreativeman says:
You inspired me...I had my hand on hand from a previous project. I actually made several of them by pouring plaster of paris into regular latex medical gloves. You can form them somewhat by manipulating the full gloves before the plaster sets up. the letters are cut from EPS foam with my hotwire. All mounted on cardboard....thought you might enjoy seeing this, and thanks for your ible. Cman
Sep 27, 2008. 12:30 AMFullyInvolvedScientist says:
Great Instructable! Very cool!
Feb 9, 2008. 5:34 PMGorillazMiko says:
Cool! I wish I could do this. Is the Juice Co. your place? If it is, you should put the Instructables sign up on the wall! :-)
Dec 29, 2007. 9:59 PMYerboogieman says:
i have the same band saw, delta makes some pretty ok ones
Sep 12, 2007. 3:14 PMkirnex says:
Nice lookin' signs. The hand came out particularly nice, as renditions go. Another way to make it, if you're not so artistic (or perhaps just lazy like me) is to use semi-damp sand and push your own hand in it, then carefully remove it and use the impression to cast a plaster (or even paper pulp) replica. You can always tweak it with your Dremel if it has some rough edges, but if you get the sand the right consistency, it ought to be pretty true-to-form. Thanks for sharing this with us.
Jun 26, 2007. 1:28 PModecom5 says:
very nice! i'm in the signage business too! i really enjoy it. those others you posted above are pretty cool signs. i went to your websites to check out more of your work but neither of them work :(
Jun 26, 2007. 1:32 PModecom5 says:
edit: also, i like your very subtle hints that you might want the laser cutter lol
Jun 25, 2007. 10:40 PMFreakCitySF says:
So what would you typically charge a client for the Juice Creations or the Instructable sign?
Jun 26, 2007. 12:11 AMFreakCitySF says:
That's a cool little business you got going!
Jun 25, 2007. 9:31 PMFreakCitySF says:
::Jaw Drops:: awesomeness need the squigly lines on the hand! Cool stuff I never even knew what a plotter was!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:peterman921
