3D Printable Filament Filter
3,178
72
Published
Introduction: 3D Printable Filament Filter
Have you ever got a nozzle clog? Or maybe a dirty print? The most likely cause is in fact dirty filament. This may be surprising but it surprised me too. This instructable will show you various files and will have advice on which one to use. Please note that I do not own the files except for thing 799183 which I designed on sketchup and scaled it in makerbot makerware.
Step 1: The Files
Here are the files:
http://www.thingiverse.com/thing:492067/#files - the original with engravements on the bottom, you must take the filament out to install it
http://www.thingiverse.com/thing:615856 - a much easier one, you only have to bend the filament to go through the filter
http://www.thingiverse.com/thing:799183 - the easiest of all, just put it on the filament and a filter and you're done!
All of these need a filter to be inserted. I recommend using a sponge if you have very little available otherwise use filter foam as it is the best. (you could always use tissues! :)
Put these filters on top of the extruder where the filament enters or if it has a guide tube then put it before that.
You can simply wrap the filter around the filament or make a slit for it as shown above.
Step 2: Hope You Like It!
I hope you liked this instructable filled with information instead of instructions! Check out my other instructables too! Any mistakes please contact me in the comments thanks!
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    2 Comments
    thank you! please vote for it in the mind for design contest!
