3x3x3 LED PVC Light Cube
 by swimscience
Step 5: Cut the PVC
Depending on the size of the cube that you want to make, the sections of pipe will all be different lengths.
Be aware that you will have to do some math.... ooh. Shocker.
A caliper can be very helpful for finding all of the correct dimensions. When I  created the cube, my measurements were pretty funky because  PVC fittings vary in length so, in your best inetrest,  I have left my measurements off.
The important thing is that the total for each side ends up the same so that the pieces fit together to make the cube.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
