3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
4-3/4 oz Ultra-light Backpacking Kitchen (video demo)
Step 3Scoring and Cutting the First Can
First Setup:
This set up is to make the score line on the lower half of the first can.
1. Clamp a razor to your workbench 1.5" above the surface of the bench.
2. With the can upright, slowly rotate the can against the razor with only slight pressure.
3. Once you have made several passes around move to the next setup. try not to puncture the can
note: do not open the can of beer, it is easier to work with the can pressurized.
Second Setup:
This setup is to make the score line on the upper half of the first can.
1. Clamp a razor to your workbench 2.5" above the surface of the bench.
2. With the can upside down slowly rotate the can against the razor with only slight pressure.
3. Make several passes to insure a good score line.
4. Use the clamped razor to carefully puncture the can along the score.
Be ready with a sink or bucket or be able to get outside quickly. (things get messy here)
5. Carefully work your thumb in to the puncture as shown in the picture, and slowly work your
way around the can. The can should separate along the score line if it was done properly.
6. Go back to the first setup and repeat steps 4 and 5 with the other score line.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
59
Author:thatoneguydavid
