3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
4-AA USB Charger for Cellphones & MP3 players
Mabuhay! This instructable is a simple, portable and easy to use device. It is portable because I want my stuffs to be "on the go" anytime and anywhere -- especially during long travel and blackouts. It is a charger made for any kind of device or gadget that re-charges using USB charger like Apple iPod and Motorola and other phones. I don't have great knowledge in electronics so I made one without using capacitors, resistors and etc. Hope you like it.
Step 1Materials needed
Materials needed
Check out the photos.
The USB receptacle I used came from our broken CPU.
11 comments
Sep 5, 2011. 2:57 PMaussa says:
Hi! nice hardware work, but dont think it will be reliable as when the batteries start to discharge they will reach 1.1 volts giving a total of 4.4 volts which is below usb standard voltage.. My recommendation is to use 5 rechargeable batteries with 5Volt low drop out regulator that can regulate at 5.5 volts input (5.5/5 = 1.1Volt/cell)
Also 1.2v rechargeable batteries are charged at 1.4 volts per cell, which gives 5.6 volts for 4 cells which is above the USB standard.
Hope the above adds value to your design.
Keep the Good Work coming ;)
Jul 12, 2011. 9:38 AMauggie003 says:
I made one also out of a Lego battery thing for a robot lego monkey.
it used 6 AA batteries at first, but then I soldered a few wires and a diode and a switch (to change the current flow in case the voltage goes too high). and i just tested it out as I am testing this and it works!!!
May 19, 2011. 2:56 PMauggie003 says:
I tried this with my ipod touch 2nd generation and...
Nothing Happened!
I heard somewhere that you need to put resistance to the data pins or something?
I don't understand
May 29, 2011. 3:08 AMaekara says:
on the usb port try touching the data pins together
(the data pins are the D+ AND D-)
Jun 14, 2011. 11:59 AMauggie003 says:
or you could put a 100K ohm resistor on each resistor and have them connected to hot.
the main voltage has to be between 4.8 and 5.2 volts
Jun 15, 2011. 8:00 AMaekara says:
yea i know that but i did this becouse i din't have a 100k ohm resistor so i just touched them and it works!
Jun 16, 2011. 1:10 PMauggie003 says:
Thats cool
Havent tried that yet
Thanks
May 7, 2011. 1:03 PMaekara says:
i think ist better if you put a blocking diode between the positive leg of the battery pack and the usb connector
you can fing blocking diodes inside old wall adaptors,just use your soldering iron to desolder one diode
and also make sure that the white mark on the diode it whe "away" which meens that the white mark will be connected to the usb connector
HOPE I HELP AND ALSO
GREAT INSTRUCTABLE ;)
Jan 18, 2011. 6:50 PMDr. Pepper says:
Cool! What an awesome idea!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:acosicris
civil engineering student
