Remove these ads by
Signing Up
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Also 1.2v rechargeable batteries are charged at 1.4 volts per cell, which gives 5.6 volts for 4 cells which is above the USB standard.
Hope the above adds value to your design.
Keep the Good Work coming ;)
I'm not really good at electronics, i just try it out with 4 batteries.
Your suggestion is noted and I'm considering it when I "edit" my ible in the future..
Kinda busy with my studies now. :D
Thanks again!
it used 6 AA batteries at first, but then I soldered a few wires and a diode and a switch (to change the current flow in case the voltage goes too high). and i just tested it out as I am testing this and it works!!!
Nothing Happened!
I heard somewhere that you need to put resistance to the data pins or something?
I don't understand
(the data pins are the D+ AND D-)
the main voltage has to be between 4.8 and 5.2 volts
Havent tried that yet
Thanks
you can fing blocking diodes inside old wall adaptors,just use your soldering iron to desolder one diode
and also make sure that the white mark on the diode it whe "away" which meens that the white mark will be connected to the usb connector
HOPE I HELP AND ALSO
GREAT INSTRUCTABLE ;)
