4 Bit Binary Manual Counter: NI Multisim (Video Included)
7,715
8
Posted in TechnologyElectronics
Introduction: 4 Bit Binary Manual Counter: NI Multisim (Video Included)
About: I enjoy creating 3D models of pcb circuits. I am a student studying Electrical Engineering. I will share some cool projects & try out a few.
Hi there. New to Multisim? This is for you!
In this project we will build a simple 4 bit manual counter using NI Multisim software.
Newbie special :)
Step 1: Parts List (if Building on Breadboard)
NI Multisim Software
******Parts needed: www.bits4bots.com
FAQ:
Hey Bits4Bots I want to build this but I have only have a 74LS48 TTL.
Answer: No problem. If you use a 74LS48 TTL you will need to use a Common Cathode Display.
Step 2: Multisim Circuit Connection
Open Multisim
  • Select components needed. I have decided to use images for this process.
Click the tabs in order that are circled in red or highlighted.
Step 3: Breadboard Circuit Connection
  • Connect the top 4 pins of the dip switch to VCC (5V)
  • Connect the bottom row of the dip switch pins individually to the A, B, C & D of the 74LS47 IC
  • Connect the 74LS47 accordingly.
  • Pin 3, 4 & 5 of the 74LS47 should be powered.
  • Connect the 7 Segment Display. I used a Common Anode.
Step 4: Test the Circuit
Now that everything is connected we can now test the circuit.
A zero should show on the display when the circuit is powered.
  • When the right>>>>>most switch is on (high) the display should show a 1.
  • Flip the switch to low again.
  • Move one over to the left<<<< and flip the switch. A 2 should display.
  • To display the number 3 flip both previous switches.
  • By now you should have an idea of how the manual counter works :)
I have included a binary to decimal chart for your convenience.
Step 5: Watch Me Build This Project!
If you like this project please follow me or subscribe to my YouTube channel.
Shop safely and securely with www.Bits4Bots.com
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    3 Comments
    Thanks a simple way to understand connect display.
    Thanks for sharing.
