4 Digit Two Wire Display With Arduino
18,616
32
10
Posted in TechnologyArduino
Introduction: 4 Digit Two Wire Display With Arduino
About: I am an American teaching English at Shangluo University, Shaanxi. I like making machines that do interesting but fairly useless things - I call them Quixotic Machines.
I was working on a project where i needed a 4 digit display but when I went to connect it to the Arduino all I found were articles about having to wire up 12 plus pins. Then I found this Suli library which makes it so simple a dummy like me can wire it up with two pins (digitial 2 and digital 3).
Stuff needed:
Grove TM1637 4 Digit display
Suli library
Four_Digiit_Display_Suli library
Step 1: Connect Display to Arduino
If you have an Arduino with an I2C two wire plug then it's a no brainer.
I only had an Uno so connect display vcc to 5v, gnd to gnd, DIO to Arduino digital pin 2, and CLK to Arduio digital pin 3.
Done.
Step 2: Download Libraries
Get Suli library here: https://github.com/Seeed-Studio/Four_Digit_Display_Suli
Now I did have a problem running the demo until I copied the cpp and header files from
here: https://github.com/Seeed-Studio/Suli/tree/master/Suli_Arduino (Guess they had updates).
Get Four_Digit_Display here: https://github.com/Seeed-Studio/Four_Digit_Display_Suli
Hope you know how to install libraries.
Run the Four_Digit_Display demo in the Examples file.
Rock on!
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    10 Comments
    Can't seem to compile it - any chance you could provide more detail for step 2?
    Sorry I just saw your comment today - don't know where I have been. But sadly I don't have this stuff anymore or even the code. Hope you got it worked out.
    i am not either. i just appreciate that you made it easy to find everything i needen ;)
    Thank you, hope it helps. I'm not really an expert on this stuff but it was available elsewhere and I needed it at the time.
    Thanks, nice simple library to use the TM1637. Very straightforward.
    Thanks. Pretty easy to use. I used it for a weird clock project. Hope I have something else to use it for.
    Rock on.
    Works well with the chinese clones too
    Will it work with all 4-digit displays? Like with the same ones that need 12 wires.
    No, only the Grove TM1637 as far as I know.
