3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
4-Hour No-Knead bread.
There are many good bread Instructables already, but when making bread, you can never have too many fail-safe techniques, and this recipe works almost every time.
DOWNLOAD A FREE PDF OF THIS ARTICLE.
This is a four-hour process; you need that much time to let the dough rise. I like to throw it together while snacking on lunch, and then when I get home after school it is ready to throw in the oven.
My recipe differs from most no-knead recipes in that you do not drop it it into a heated pan. I changed the recipe because I had too many burns from handling a bread pan at 400+ degrees, and one of my Pyrex dishes shattered on me when I accidentally set the edge of it on a wet washcloth.
I hope you enjoy this tutorial and the resulting mouthwatering delicious bread.
Step 1Materials.
Materials.
Flour:
To make good bread, you need good flour. Flour which is marked "bread flour" typically has 11-12% protein (gluten) which is higher than normal flour. This allows the loaf to have good structure and texture. You can cut cheaper white flour with bread flour if you don't have enough of either.
If you are in Germany, type 550 flour works well. Thanks t.rohner and stryke!
Yeast:
I use yeast from a Polish market. While you can buy Fleischmann's yeast from the supermarket, it is really expensive, especially in packets. If you have access to an Eastern European or Balkan market, often they sell 1lb bags of yeast for just a few dollars, a huge savings over the grocery store stuff. You need a small spoonful, the amount is not critical.
Salt:
I use sea salt, but you can use any kind of salt. Salt adds flavor and slows the growth of yeast slightly. I like to put about half a spoonful in.
Container:
You need a bake-proof container with a lid (the lid saves you from having to use foil every time and results in a more consistent crust). I got my Pyrex baking dish (visible in Step 7) at a local thrift store for just a few dollars. It is really the perfect dish for this kind of thing
Ingredients:
3 cups flour.
Some salt. (see picture 2)
Some yeast. (see picture 2)
186 comments
1-40 of 186next »
Apr 12, 2012. 6:51 PMspeerclan says:
Thank you, thank you, thank you for this recipe! I have always been afraid of baking anything with yeast. I had never tried it until this bread. I started it this morning and we are just now finishing it off. WOWZA! It was so good. The instructions were perfect and I am just beside myself with excitement. I can't wait to make another and another and another. My butt and thighs will never be the same. HA!
Dec 26, 2011. 8:47 PMFamilyRoots says:
OMG, this bread is so good! My husband, our son and myself just ate over 1/2 the loaf and I may go back for more before the night is over. Thank you so much for sharing the recipe and instructions!
Oct 21, 2011. 1:56 AMbeehard44 says:
last time i tried this i completely skipped out the part where you should place it in a pot and cover it. So i decided to try it again.
I wanted to rise it for 20 hours but i'm thinking the yeast might be too reactive so i added the salt before adding water and placed the dough in the fridge
That was 18 hours ago. Now i poked it but it just dug in. Do you think it'll still come out nice?
Jul 28, 2011. 3:28 PMtictaclad says:
you say that any time less than 4 hours rising will give poor results. Is this because it doesn't rise enough or what?
Jul 28, 2011. 6:58 PMtictaclad says:
well it came out great!! i used normal flour and a lot of salt on that last part and it was soooo delicious everyone was impressed. thank you for sharing this easy and delicious recipe. but it did stick a bit despite the olive oil...how can i fix that?
Aug 12, 2011. 1:16 PMtictaclad says:
yes thats what it is. ive started to use a bread pan and oiled it before it rises and then just put it in the oven after it rises and that works much better...ive noticed that messing with the dough after it rises kind of deflates it and defeats the purpose of it rising...
Aug 11, 2011. 11:24 PMtdawber-mandeno says:
best bread i've made
Aug 12, 2011. 3:18 AMtdawber-mandeno says:
bugger
the first time made this i had with fish and chips
ill have to make second one post back in a day
Jul 28, 2011. 12:26 AMtdawber-mandeno says:
add some sugar (yeast have to eat somthing) like half teaspoon good amount for this
Jul 12, 2011. 11:51 AMsunshiine says:
I will definetely try this. Thanks for sharing your hard work.
May 23, 2009. 3:53 PMacrollet says:
Just tried this for the first time - turned out delicious, crust was perfect! The crumb is perhaps a small bit denser than I would prefer, do you have any suggestions for making it rise a little more? I may have gotten a little too much water in the dough, perhaps that was the culprit... Used bread flour and one packet of quick-rise yeast. Thanks very much for the excellent tutorial!
Jun 6, 2009. 8:36 PMjradi says:
One of the best loaves I've ever made, and I've made a LOT of bread! The crust was amazing. I let the loaf rise for almost 12 hours (because I forgot about it) and it still came out wonderful.
Jun 6, 2011. 5:54 PMacajjou says:
At what point can you let it go longer - during the "four hour rise"? Should you refrigerate at any point during a longer time period? And after the longer rise do you follow the directions the same way you would if you had only let it rise 4 hours?
(I'd like some bread for tomorrow's dinner, but it's way too late to do the entire process tonight!)
Jun 6, 2011. 6:40 PMjradi says:
It's a very forgiving recipe. I let the initial rise go for 12 hours, then followed through with the rest of the recipe without changing anything. Actually, that's my new routine. I mix it up in the morning before work. I come home between 8-10 hours later and do the last few steps and bake it. Beautiful dinner.
Jun 6, 2011. 6:59 PMacajjou says:
Thanks, jradi - I'll try that tomorrow morning. :)
Jun 7, 2011. 3:14 AMjradi says:
You can actually go quite a while and it still tastes great. Here's pretty much the same recipe, with it rising for14-20 hours!
http://www.nytimes.com/2006/11/08/dining/081mrex.html
Jun 9, 2011. 6:38 PMacajjou says:
It worked perfectly and tasted the same as when I've done it with just 4 hours. I think I have a new bread baking routine in the works!
May 23, 2009. 3:56 PMacrollet says:
Forgot to mention - I used a crockpot insert w/ pyrex lid, and it worked great. Used an oven thermometer to make sure I was baking at 450. (had to turn the dial a little over 475)
Jun 7, 2009. 4:20 PMacrollet says:
I have had some success actually - just last night I re-tried the recipe with these ingredients: 3 cups bread flour 1 tsp. yeast 1.5 tsp salt 1.5 cups water with 1 tsp apple cider vinegar mixed in I stirred a bit longer at the beginning to develop the gluten some more, but otherwise followed your recipe to the letter. I was very happy with the result, the crumb has the airier, springier texture that I really like. Added bonus: it's still fresh and good right now, 24 hrs after I took it out of the oven. Here's a pic:
Jun 7, 2009. 7:07 PMacrollet says:
great!! I'll be really curious to hear how it turns out for you, be sure to post :)
May 12, 2011. 6:59 PMtjinscot says:
Thank you very much for your recipe. This is now one of our favourite breads. So easy and oh sooo good!
Oct 24, 2010. 12:22 PMmagetrainee says:
I've been cooking this bread on a pizza stone just for the fun of it, but my crust has consistently turned out a bit whit and thin, any ideas as to what might help?
maybe if i brushed egg on it before cookin...
May 12, 2011. 6:52 PMtjinscot says:
My advice is just bake it in the pan with a lid on, as instructed. The steam in the pan will create the desirable thick crust. Excellent results every time.
Oct 24, 2010. 2:11 PMmagetrainee says:
just finished the bread
made one loaf with olive oil on the outside and the other with egg brushed onto it and the egg produced a FANTASTIC crust for all those interested
I also baked it on a baking stone at 450 with a dish of water underneath
Apr 29, 2011. 11:44 AMjamesorlov says:
Thanks a lot for your instructable! Now i'm waiting for dough to raise ))
Apr 29, 2011. 3:57 PMjamesorlov says:
It's GREAT!
Very crispy, and tasty! Especially with salt and butter! Thank you!
Here are my first bread:
Jan 16, 2011. 4:19 PMcrankyjew says:
ah man, this recipe is truly fantastic!
i've gotten really nice results using 1 cup whole wheat flour to 2 cups white, with a spoonful of sugar thrown in. i usually brush some egg on the top to help a really awesome crust form.
Oct 3, 2010. 4:01 PMallbeef says:
just made mine today, at first when i pulled it out of the oven i was dissapointed because the crust looked rubbery and lame and pale. but then when it cooled, i ripped off a chunk and it was amazing! really good recipie!
1-40 of 186next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
141
Author:daniel_reetz
Hacker, Artist, Researcher, and founder of the diybookscanner.org community.
