Introduction: 4 Ways to Make a Harry Potter Wand
Picture of 4 Ways to Make a Harry Potter Wand
There are plenty of awesome ways to make a pretty nice looking harry potter wand. But in this tutorial, I will show you 4 of the most popular methods of making your own wand!
Step 1: The Hot Glue Wand
Picture of The Hot Glue Wand
One of the easiest ways to make a wand is with paper, scissors, and hot glue. First, roll up your sheet of paper (corner to corner) and glue in place. cut off the two pointed ends and fill them in with hot glue. Now, add all sorts of fun designs to your wand with the hot glue. I did a ring on eacf end of the handle. Then, I made a dotted spiral thing on the handle and a leafy vine crawling up the shaft. Once you are finished with the hot glue designs, you could paint it however you want. I spray painted the handle of my wand black, the shaft got painted yellow, and the vine thing got painted white. I chose yellow black and white for the hufflepuff house in the movie :)
Step 2: The Stick Wand
Picture of The Stick Wand
Find a descent stick that isn't too thick and is fairly straight. Mark a line about 3 or 4 inches from the end of the stick and whittle everything from that point on. Now, narrow down the whittled part a little and you could sand it if you'd like. I also lacquered mine after I was finished.
Step 3: The Clay Wand
Picture of The Clay Wand
First find a dowel or extremely straight and thin stick. Next get some sculpey clay. You could do whichever wand you would like to do but I did Mad Eye Moody's wand. First I rolled a ping pong ball sized ball of clay. I put this on the end of the stick and stabbed it on a little further and I smoothed the clay on. Then I  added a clump of clay below the ball of clay. I now added little marble size balls all around the clump of clay and smoothed them out. I baked the wand at 250F degrees for 1 hour. Once it was cool, I painted it black. I did this same kind of thing for Remus Lupin's wand and Fleur Delacour's wand.
pyromaniac123456789 (author)2013-11-26
Clay wand would be easier to make elder wand, but having a stick wand with a glue gun handle would be more like harry's
I think I know the fourth! I call it sculpt, mold, and cast!
Step1: You sculpt a positive mold of your wand in polymer clay (not totally unlike the third method),
Step 2: You make a negative mold for your wand in plaster of Paris
Step 3: You use the mold to cast the final wand in silicon rubber, giving it a piece of metal rod to give it structure. Then, you give it a wood-like finish.
Yep! You could also use epoxy putty as well, although, you'd probably need a lot of it to make an elder wand!
Dinoman217 (author)2015-11-05
This is great! You only showed three, but it's great!
E Daniels (author)2013-11-01
That is so cool I voted
About This Instructable
23,627views
63favorites
License:
Bio: I love woodworking and making fun stuff on the lathe, I really enjoy making stuff and posting it on this website, and I love the ... More »
More by HPandLOTR:American Patriot PenUltimate Lathe Dust CollectionRustic Pallet Sign
Add instructable to:
