Step 2Connect the webcam to the lens
Next you have to go to the local hardware store and find the pvc part that fits your lens or gets very very close to fitting so you can easily fill up the gap with some tightly wound tape. I made 2 of these telescopes and didn't have problems finding a perfect match, but that could just be luck. You'll also need an endcap for this phase.
Make a hole just as large as the optical tube of the webcam exactly in the middle of the endcap. It must be exactly, or performance will reduce. Now you can put everything together. Fit the adapter to the lens, put on the endcap (I needed an extra piece of pipe to reach the endcap diameter) and put the webcam in. The hole in my encap was to tight I could just lock the webcam in. If yours is a little looser, use some tape. The webcam must be about 3cm behind the rear end of the tele lens.
Now you can try it. Hook it up to a pc and put it on a tripod. Aim at something more than 50 meters away and see if you can focus by turning the focus ring of the tele lens. If you can't, then you must play with the distance between the tele lens and the webcam. You may need to change the length of the adapter a bit. Once this is done, you can glue (or tape) everything together. Make sure that all the parts are perfectly aligned in a straight line, this is also vital for the best results.
Add Comment
