3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
400V Stun Baton!
400V Stun Baton!
 I was so annoyed at my seatmate that I vowed to pump 400 volts, 0.04 milliamps, 16 watts of calculated power into them in DC form. It all started when they started this quite insulting song that's been going around our part of the isle recently, so I reconsidered modifying that electric mosquito killer in order to make them think otherwise. This is also going to be used against my bus-mates (which are all too annoying..) and in self-defense. I opened it up so that I could see the circuit, and it was a relatively simple one. I am yet to reverse-engineer the circuit, but I could tell you that there was a 400V Mylar capacitor and a small transformer (inductor) in there. It's just a simple mod that involves opening up the unit, cutting wires and reattaching, then putting it back. The electric mosquito killer is in the shape of a tennis racket. It had some odd design in the middle. The business end consisted of 3 grids charged in the following order: negative, positive, negative. While I was still working with it, I got electrocuted (fingers, off course) and it felt like I was being thrown forward. I also considered turning it into AC (it could be a pure or modified sine wave, square wave also works); my friend kept saying, "remove the damn diode!" but I never did until I drew up the circuit so that I could know which diode to remove. I also considered adding 10kOhms worth of resistance in there in order to decrease the amperage further to increase safety. As long as it incapacitates someone for a while, then it's good. If YOU'RE (I meant my seatmate or bus-mate) READING THIS, <insert evil tone> watch out....
EDIT: I remeasured, and somehow, the voltage went up to 565 and the amperage went into the kill zone of 2.3 milliamperes. Now I have to recalculate how much resistance I need for this to not kill anyone. I have recently electrocuted myself with it, and it hurt much much more than I remember.
16 comments
Jan 11, 2011. 7:44 PMthewizard42 says:
Electrocution is death by electricity. I highly doubt you are dead
Nov 16, 2011. 9:52 AMmichaeleoni says:
you can be electrocuted and sientificly speaking if you are "shocked" by any thing over .1 milliamperes its electrocuted and he never said it stayed .o4
Jan 12, 2011. 6:28 AMthewizard42 says:
No, the term ELECTROCUTED is to DIE regardless. The term you are looking for is shocked
Oct 29, 2011. 7:53 AManonymouse197 says:
Well to electrocute is to 'injure or kill someone by electric shock' so you could have been electrocuted, if you were injured!
4r1
Oct 29, 2011. 9:23 PManonymouse197 says:
Possibly, or the story of the man who used the handle of an axe to hit another mans hand away from a live cable, but hit down rather than up so broke his wrist.
Oct 26, 2011. 4:13 PMRobot Lover says:
I believe that the lethal amount of current is 200 milliamps.
Oct 28, 2011. 8:12 AMRobot Lover says:
Yes, you would not need much current in a shock at the heart to be lethal.
Mar 12, 2011. 8:33 AMbeehard44 says:
the transformer providing the oscillations isn't tuned for 9v. When you add the bridge rectifier, it does nothing because the output is pulsed DC (i checked your circuit remember?)
and it's an update, an edit is when you edit your actual instructable
Jan 24, 2011. 12:37 PMnfk11 says:
cool
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:nutsandbolts_64(The Machine Code)
Electronics enthusiast, gun enthusiast, violinist, linguist, HTML programmer, semi-mathematician, to-be chemical engineer, writer, reserved, preserved, to serve, retro, living in Metro, lifestylist, b...
more »
