3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
40x RGB LED Controller with 8-bit PWM and Selectable Patterns
A relativity simple driver I have designed for use in Infinity Mirrors, Case Mods and anything that could use some color.
Controls 40x Common Cathode RGB LEDs in 8 channels with 8-bit PWM, 16 million color combinations.
Five groups with 8 independently controlled RGB LEDs each, are arranged end to end (square or a loop) and together with seamless patterns it appears that all 40 of the LEDs are controlled by themselves.
Driver measures 2.5" x 3.5" x >1"
Kits including PCB+ all component parts and 40x 5mm RGB LED can be purchased in my store at www.ChromationSystems.com
or a Developer Package with all the files needed to recreate this project can be Found Here
Add a suitable PSU and matching panel mount barrel jack to your Order
The PCB for this project is easy for a moderately skilled solderer, wiring the light bars is confusing, be sure you know what needs to be done and can understand directions before attempting this project.
It is set up for 5 volts Input at 1.2 Amp ( Safe Estimate ). But there is a spot for a 7805 if the input current must be more than 6 volts. Not recommended as most 7805s can't handle enough current for all 40 RGB LEDs.
Complete Info is Found in The Datasheet
Kits with everything needed to recreate the Infinity Mirror Below can be purchased here.
Step 1Layout the Parts
Layout the Parts
Full kits with Controller, RGB LEDs, Wire Can Be Purchased
or a Download Package with the Eagle Files, PCB layout and HEX File Can Be Purchased.
Controller Parts List:
- PCB, Eagle Files and PCB Layout
- Programmed 16F870 or get the HEX File
- 28 pin socket
- 3x 18 Pin Socket
- 2x TD62783APG, source driver
- 1x TD62083APG, sink driver
- 2x 10k 1/4w resistor
- 1x 20 mhz Series Oscillator
- 1x 2 pin Housing
- 1x 2 pin Header
- 4x 20 ohm 1 watt resistor
- 4x 16 ohm 1 watt resistor
- 4x 75 ohm 1 watt resistor
- 2x 10 uF capacitor
- 2x 1 uF capacitor
- 1x 5 pin terminal
- 1x 4 pin terminal
- 3x 3 pin terminal
- 1x 2 pin terminal
- Wire, 22ga dual strand works good, amount depends on how long your light bars are.
RGB LED bars:
- PCB or Perforated board to mount RGB LEDs onto, perf-board should be 3 holes wide.
- 40x 5mm RGB LED, common cathode (kit includes a few extra)
Tools:
- Soldering Iron
- Solder
- Wire Cutters
- Wire Strippers
Optional:
- Volt Meter
2 comments
Nov 3, 2010. 10:53 AMcurly B. says:
great work!
http://www.instructables.com/id/cool-DIY-infinite-LED-tunnel/?&sort=NEWEST&limit=40
Jun 15, 2010. 1:33 PMClayfig says:
Awesome I cant wait to try building one of these for myself =] I've looked at a bunch of your other instructables and you make some cool stuff.\ keep up the good work!!!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
61
Author:ChromationSystems(www.chromationsystems.com)
Designing electronic creations from microcontrollers, LEDs and anything else I can pull out of a dumpster and make use of. Check my Profile
