mvi_1059.avi4 MB
Remove these ads by
Signing UpStep 1: Gather the parts
Here is what you will need:
1 - Timer 555 8 pin IC
1 - 2N3905 PNP general switching transistor
1 - 2N3053 NPN general purpose amplifier (I dont know if this is a switching or amplifer but I used MPSA2222A instead and it worked fine, I also tried 2N3904 and it worked, but a littler worse than the one I used)
20 - red LEDs (although you can use any color choice you want)
20 - blue LEDs (although you can use any color choice you want)
1 - LED (this is used to verify if your circuit works, can be any color)
1 - 1uF Electrolytic capacitor
1 - .1uF disc capacitor
1 - 150k resistor
1 - 4.7k resistor
1 - 160 ohm resistor
1 - 220 ohm resistor (although I used a 160 ohm)
20 - 100 ohm resistors (I didnt have 20 so I used 10 of 100 ohm and 10 of 120 ohm)
1 - 6V source
wire
Visit Our Store »
Go Pro Today »
A video would be nice.
Could this be modified to not do flashing at all, or to flash at such a quick rate that it is not visible flicker? (I'm assuming that removing the flash altogether would be hard on the batteries, if they even can supply enough current.)
I'd like to just run this many batteries off AAs without requiring a million resistors, or losing 1/3 the energy as dissipation through the resistors.
_
- ofcourse there are three little lines but everyone of those should be connected to ground or in this case the negative (-) side of battery
The simpler ones show (+) & (-) wires so us novices can follow them. This diagram has many different ground symbols when I believe it's where the (-) lead goes.
I'd actually never seen that site before, so I got 2x value from reading this instructable. Thanks!
similar flasher circuit but the rate of flashes is variable
the difference is it has a potentiometer taken from
http://electronician.blogspot.com/2010/11/led-flasher-circuit-using-555-ic.html
Please clarify.
Thanks!
