3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
41 LED Flasher Circuit using 555 IC
Step 2Build the circuit
Build the circuit
So here is the layout of the circuit. It is pretty basic. Here are some notes so you can better understand what is going on.
The notes were taken from the page mentioned later.
"Two sets of 20 LEDs will alternately flash at approximately 4.7 cycles per second using RC values shown (4.7K for R1, 150K for R2 and a 1uF capacitor). Time intervals for the two lamps are about 107 milliseconds (T1, upper LEDs) and 104 milliseconds (T2 lower LEDs). Two transistors are used to provide additional current beyond the 200 mA limit of the 555 timer. A single LED is placed in series with the base of the PNP transistor so that the lower 20 LEDs turn off when the 555 output goes high during the T1 time interval. The high output level of the 555 timer is 1.7 volts less than the supply voltage. Adding the LED increases the forward voltage required for the PNP transistor to about 2.7 volts so that the 1.7 volt difference from supply to the output is insufficient to turn on the transistor. Each LED is supplied with about 20 mA of current for a total of 220 mA. The circuit should work with additional LEDs up to about 40 for each group, or 81 total. The circuit will also work with fewer LEDs so it could be assembled and tested with just 5 LEDs (two groups of two plus one) before adding the others."
14 comments
Apr 14, 2010. 8:40 PMhummvee3 says:
I bought everything needed to build this but i have a problem understanding how to read a schematic and the photo does not show where all wires go. if any one has built this please email me some photos to hummvee3@yahoo.com it would be much appriciated. i would really like to make this and this is my fisrt time making a circuit of any type and i like the idea. please help with photos that shows where to place wires on the bread board. thanks again
Apr 19, 2011. 9:10 AMbenny_resendez says:
did anyone ever send you anything to help on your problem? If so can you send it to me I am trying this for a project and just cant seem to figure it out.. benny_resendez@yahoo.com
Jan 14, 2011. 11:41 AM72bobbert says:
the ground is negative. the leade on the transistor that has the arrow is the emitter, the center one is the base, and the other one is the collector. all l.e.d.'s are polarized. if you look at the two leads one will be longer than the other. the shortest lead is negative. thats basically all what a novice wouldnt know. go to bluedashlight.webs.com to see my modified schematic for 12-14 volts.
Oct 17, 2010. 11:43 AMrcisneros says:
I know what you mean. A lot of diagrams are made for people who already know electronics.
The simpler ones show (+) & (-) wires so us novices can follow them. This diagram has many different ground symbols when I believe it's where the (-) lead goes.
Jul 20, 2011. 8:13 PMMROHM says:
You are right on this one my Friend!!! My only advice to you is to build or breadboard Simpler Circuits and once you feel comfortable you can move on to more complex ones. I have been in electronics a long long time and enjoy simple circuits over complex circuits,,,,because;;; 1) They work~~~~100% of the time and 2) they are easier and faster to construct, 3) you can build your knowledge faster so you can tackle the tougher circuits at a later date!!! Good Luck and Happy Building!!! I must go now,,,, I smell my Weller!!!!
Jun 22, 2010. 11:08 PMmiiwii3 says:
it does show where all wires go you just need to use jumper wires to connect things. the schematic does not show wher wires go but what they connect to just draw it out trust me i built this and like from 6 to 2 just use a jumper wire either over the ic or around it. it is easier if you use a breadboard for this.
Dec 30, 2008. 3:18 PMgeeklord says:
so do PNP's stop conducting when there is a current at the base?
Jun 22, 2010. 11:12 PMmiiwii3 says:
positve negative postive negative is the base and since the timer output is + - + - it turns on and off with the positve and negative votage. its like you quickly switch the red a black wire on the battery it would go + then when u switch it becomes - make sense? basically the 555 switches th polarity for you at a specific rate.
Feb 23, 2010. 2:32 AMRajeshkm says:
hai geeklord... the the transistor is said to be in on state ,only when it gets a forward bias across its base and emitter....the polarity configuration depends up on the type of transistor .. NPN or PNP...
Dec 31, 2008. 9:42 AMgeeklord says:
K, just wanted to make sure that radio shack wasn't doing what they do best!
Jun 17, 2010. 1:39 AMarkangel888 says:
can i replace the 2n3053 with bc184 or c829?
Jun 22, 2010. 11:01 PMmiiwii3 says:
maybe you can also replace it with a NTE128. the other one you can replace with NTE159.
Mar 23, 2010. 7:09 PMpgg123 says:
Is it possible to wire the 555 to make the LEDs pulse instead of flashing?
Apr 6, 2008. 10:23 AMCobra9197 says:
Can I changed '2N3053'in your diagram in step2 for '2N3055' ??????? Thank you
Apr 28, 2008. 11:18 AMnbl2 says:
yes that is what i did and it works perfectly
Jul 3, 2007. 8:59 PMnialpmatk04 says:
hey i added a five meg pot for r2 and changed r1 to 2.6 k and the flash is very variable with a low duty cycle. works great i built it in an old vhf radio box and it looks just like a fire fighter light used by volenteer fire fighters in my town.
Oct 22, 2006. 6:26 PMsysadmn says:
If you use a design from another source, it would be polite to mention the original designer and give a link. It's more work than you might think to document these things, and we ought to encourage those who take the time to share.
Feb 19, 2007. 7:14 PMmu0p says:
who is the original designer? Link??
Feb 23, 2007. 3:04 PMsysadmn says:
Then I am a moron for overlooking that, and apologize. Did you ever build a perfboard or circuitboard version? That would be interesting to see.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:supes
