Here's a simple 433.92 MHz short range radio beacon that may be handy for locating downed R/C planes, lost ballons, model rockets - or perhaps hidden transmitter "fox hunts"! 433.92 MHz is internationally a free band slot, and although only low power transmitters (10-25 mW) are legal, UHF signal punch thru' light vegetation etc is superior to 2.4 GHz microwaves.
It's based around a cheap (~US$5-10) low power (a few mW) Keymark/Spirit-On TXC1 data transmitter, fooled into transmitting audio tones generated by a cheap PICAXE-08M microcontroller. Ranges are up to a km line of sight, dropping to 100-200 metres thru' light vegetation and wooden buildings etc. Compared with flashing lights & beepers, the beauty of a wireless locator relates to all hours convenience & simple direction finding even thru' light vegetation etc. A cheap "sniffer" receiver ( based around a companion RXB1 Keymark receiver module) is shown at => http://www.picaxe.orcon.net.nz/433rx.htm
NOTE- keep this simple locator beacon approach in perspective! Do not expect it to locate the likes of your $$$$ FPV (First Person View) model plane downed miles from anywhere in deep woods. For serious locator use, more powerful transmitters & GPS encoding should be considered. These of course can be costly, have higher battery drain and may be tedious to configure .
UPDATE - early 2012: Chinese firm Dorji have recently released some cheap (< US$10 a matched TX/RX pair) ASK 433 MHz data modules that significantly improve this beacon! Their transmitter is particularly appealing, as it's power is boosted to a (legal) 25 mW, giving ranges some 4-5 times greater than the KeyMark/SpiritOn equivalent ! A sensitive UHF scanner can still detect it thru' light vegetation etc to ~500 metres, and LOS (line of sight) several km ! The Dorji receiver, which usefully can also be persuaded as a band monitor, is somewhat more sensitive than the Keymark as well.
Since these Dorji ASK modules have shown themselves clearly superior, more versatile, smaller and far cheaper they're now recommended instead of the Keymark! As circuitry & layout will need to be slightly changed however (see => www.picaxe.orcon.net.nz/dorjiask.htm & a Dorji based 433 MHz "sniffer" receiver => www.picaxe.orcon.net.nz/dorji-tonerx.jpg ), the Instructable is presently still Keymark module based.
Update -Nov. 2012 : A superior Dorji based tape measure antenna Instructable is now available => www.instructables.com/id/433-MHz-tape-measure-antenna-suits-UHF-transmitte/
Remove these ads by
Signing Up
Visit Our Store »
Go Pro Today »
I am thinking this would work perfect for a "hide and seek" sort of game for my kids - we are working on some map reading and orientation skills - before a big backpacking trip.
Would this be a good fit for a game where I used 6 or 9 of the transmitters as hidden "treasures" (say in a waterproof box or pvc pipe) then gave the kids a map with the locations marked and let them have a receiver where a LED light or group of lights would come on as they got closer???
I have seen some references (including one in the link below) to these being used in "fox hunts" or geocaching - but hadn't seen anything specific so as a relative newbie I thought I maybe should confirm. :-)
Thanks again for all the great information!!
Further sleuthing with the Dorji module has revealed a valuable signal strength tap that suits enhanced work- refer attached pix. In conjunction with a 433 MHz tape measure Yagi antenna absolutely remarkable performance has resulted.
I'm still organizing this as a brand new Instructable, but have uploaded pix to =>https://picasaweb.google.com/113235065280579741262/Dorji_DF
Stan
Although of course NOT as sensitive as a dedicated $$($) UHF scanner, such a 433 MHz data module hack is dirt cheap,educational,dead easy to use & is particularly handy for diagnostic checks on all manner of 433 MHz devices. Investigate (by HEARING/SEEING band activity) the likes of wireless door chimes, backyard weather stations, car remotes.garage door openers, wireless data devices,local 433 MHz band interference,pickup antenna and device siting benefits etc etc. HIGHLY RECOMMENDED!
great resource & helpful script which allows to create different types of rf sending/receiving devices !
and, much more important:
thanks so much for posting the links!
will have a look at it asap - (late over here - 4.20 AM)
(did some research meanwhile and found another really helpful example on instructables
http://www.instructables.com/id/Wireless-temperature-sensor/ )
besides:
orcon has plenty of sources too, thanks a lot, again!
Best Regards
Marc
hence commands such as HIGH, LOW, SLEEP and GOTO are not easy enough to master for me yet :
- would you mind to hint me towards how to code this
or
probably post a link for similar examples ?
apologies for being that helpless - i did my googling
and did not find one example for a newbee-easy-to-understand-
picaxe rf transmitter-receiver example
including code and schematics example yet
(not to mention a "breadboarded" or "circuited" image coming with it)
and was happy to find your instructable!
however: thanks for posting all this!
may i ask which code you are refering to ?
http://www.picaxe.orconhosting.net.nz/
- Multi-tone (SMT) Hellschreiber
which -amongst other links- links to ...
http://www.members.westnet.com.au/page3/picaxe-08m_mimi_28mhz_beacon.htm
which links to ...
http://www.members.westnet.com.au/page3/PICAXE-08M_Mini_28Mhz_Beacon_Code_Ver2.txt
