iImage Information
Instead of tossing damaged 45s in the garbage or melting them into coasters, try making a new decoration for your home!
Step 1Arrange records
iImage Information
Start with some CLEAN, used 45s that can no longer be played on a turntable, but shouldn't be thrown out. I used 10 for this wreath. I started by placing two next to each other, and one on top, continuing the repeat pattern until the circle was complete. I used E600 craft adhesive to glue the records together- I'd avoid hot glue, as these are pieces of vinyl!
If you're just trying to seal it so you can hang it outside; it would be even easier (and more waterproof) to just use a spray can of Krylon indoor-outdoor clear finish--which is also available in matte (flat) finish or glossy.
