48V Electric Flat Tracker by Radioactive_Legos
Contest WinnerFeatured
About a year ago, my dad and I had the idea to convert a beach cruiser bike into an electric motorcycle. We purchased the bike and all the parts necessary and got to work. We modified the frame and rebuilt the bike from the ground up. When we finished, we were extremely satisfied with the results - a 48 volt, 15 horsepower board track racer.
Step 1: The Components
We started with a Felt beach cruiser because it had the right look. We wanted a beefy bike that could fit all the components. The goal was to keep the center of gravity as low as possible. Here are the rest of the main components we purchased:
- Briggs and Stratton Etek motor (now discontinued)
- Alltrax AXE 300-amp programmable controller
- Magura 0-5K ohm twist-grip throttle
- 4 x 12V, 21Ah sealed lead acid batteries
- Avid BB7 mechanical disc brakes (160mm rotors)
- #35 moped chain
- 13-tooth drive sprocket
- 66-tooth rear sprocket
- big power switch
- 300-amp fuse
- 8 1/4 in. stainless steel motor mount (this replaces the original bottom bracket)
Step 2: Front Fork
We removed the original rigid front fork and replaced it with a Manitou suspension fork. We also bolted on an Avid disc brake set to the front end. We chose to go with mechanical discs instead of hydraulics simply because they are less expensive and less complicated. The Avid BB7's are fully adjustable. You can dial in each pad separately.
Step 3: Rear Brake Mount
Because the bike we purchased used coaster brakes (pedal backwards to stop), we had to fabricate a mount in the rear to accept our other disc brake. We used a jigsaw to cut out a piece of steel for the main shape. Next, we used a drill press to tap holes for the brake.
Step 4: Rear Hub/Sprocket
The rear hub we used is designed as a "dual disc" front hub. It has a standard mountain bike 6 bolt disc pattern on both sides. We took a blank 66 tooth rear sprocket and drilled it to accept the 6 bolt pattern. The alignment of the hub, sprocket, and disc rotor are critical.
Step 5: Rear Drive Complete
Here the brake mount is welded on, the wheels have been laced to the hubs, and on the right side, the seat stay has been crimped to get clearance from the chain and sprocket. The axle tension adjusters we used were from Answer Products.
Step 6: Motor Mount and Foot Pegs
The motor mount (cut from the same piece of steel as the brake mount) is welded into the stainless steel ring and the ring is welded into place, exactly center, replacing the original bottom bracket. The foot peg mounts are made from a couple of old work light stands welded together.
Step 7: Mount: Drilled and Welded
Centering the motor ring is very important. The ring is a section of a stainless steel light post salvaged from a scrap yard cut to 4 1/4 inches wide. It is 8 1/4 inches in diameter which leaves about a 1/8 inch gap around the motor. It is perforated on the drill press to allow air flow to the motor and notched on the right side for chain clearance. The motor mount is welded offset inside the ring for optimal motor shaft and chain placement. Mounts are welded to the underside of the motor ring to accept the removable foot peg assembly. The foot pegs themselves are aluminum BMX "grinder" pegs.
Step 8: Seat Mount
The original seat post was removed, cut short, and welded on the seat stay bridge over the rear tire and a gusset was added for strength. A rubber cap was put over the existing seat tube, and the seat clamp was flipped and reversed.
Step 9: Welding Complete
Here you can see the bike coming together. The beefy wheels and lower saddle position give it a retro look. Notice the brazed on eyelets for the rear brake cable routing.
Step 10: First Assembly
The battery trays were fabricated from aluminum stock. Each tray was then riveted together and bolted to a right and left panel. The panels are then bolted to each side of the frame. Note the power switch in the center. The right and left panels are asymmetrical to accept the terminals on the back side of the power switch. The controller is mounted upside down under the top tube with the terminals pointing backwards.
Step 11: Final Assembly
After we had finished the assembly, we had to wire it up. Within a few hours, we were testing it up and down the parking lot. It really accelerates quickly and we have not tested it for top speed. It is estimated to do better than 50 mph.
The controller we used can connect to a PC via a serial (RS-232) cable. With the freeware on their site, alltraxinc.com, you can view statistics in real time, change settings, and adjust the power curve for the throttle.
Step 12: The Maiden Voyage
This was the first chance we really got to ride the bike to its (almost) full potential. The bike is smooth, quiet, well-balanced, all torque and pretty fast. It's a blast to ride! After finishing it, we decided to call it the EV-12 for various reasons.
1-40 of 362Next »
1up says: Aug 10, 2010. 3:51 PM
Without a doubt, the nicest electric bike I have ever seen. Amazing work.
iminthebathroom says: May 25, 2011. 1:36 AM
When I talk about instructables to people, I use examples of exceptional work to illustrate it orally to them, yours is one of the ones that tops the list!
Kayak Kid says: May 14, 2013. 7:20 PM
how much did it cost
JohnnyD77 says: Jan 10, 2013. 1:06 PM
About how much did this cost you?
MartijnD says: Jan 4, 2013. 7:15 AM
Nice project! Aren't you concerned about crash safety, if the lead-acid batteries burst and the liquid contact your skin it will give 3rd degree burns, if you are really unlucky, even up to the bone.
aetourneau says: Sep 19, 2012. 7:27 AM
It is a amazing work!
I would also like to make one but where is that I could get back a motor ?
Sorry if y have made some mistakes, I'm French.
karl w becker says: Sep 10, 2012. 11:45 AM
In my exerience In CT. If you get stopped on an electric the cop calls it in and get's told to "get real" and let's you go. Once again Law has not kept up with the technology.
piterrock says: Aug 12, 2012. 11:19 AM
alguém sabe me informar um bom motor elétrico pra colocar em uma bike chopper que estou montando , o aro traseiro é de carro ???
The MadScientist says: Apr 24, 2012. 6:35 AM
How many watts is your motor?
charlesfries says: Jul 30, 2012. 4:06 PM
It would be 11,520 watts or 15 HP
ComixDude says: Oct 9, 2011. 7:30 PM
i am sure someone already asked but, how do you charge them ?
jwesson says: Jul 24, 2012. 8:55 AM
remove and charge individually same as marine battery or get a charger for the whole pack on eBay. (Scooter E Bike Electric Bicycle 48V Battery Charger 20AH 110V Input For USA CA)
Pengwin3 says: May 9, 2012. 5:55 PM
Well, it runs off of 4 12v batteries, so you could just hook it up to a car battery charger.
rangerweavere says: Dec 13, 2011. 8:46 AM
With the amount of speed that you claim for the EV-12 to reach you would have to get it registered as a motorcycle or risk the possibility of large fines and possible jail time.
isaacwilk says: Jun 28, 2012. 12:53 AM
If you ride it on private property with permission, you don't need to get it registered. I don't think the cops will mind too much as long as you only ride it around the neighbourhood responsibly, and don't annoy any neighbours or cause problems with traffic.
woodstockbirdy says: May 19, 2012. 11:04 AM
God you are stupid. It's a bike, thats electric. No where does anyone say you have to get it registered as a motor bike. They sell commercial ones all over the world, and the don't have to get theirs registered and they go way faster.
timmytwogunz says: Sep 27, 2012. 10:50 PM
i live in dunkirk ny where i have a friend that has recieved 7+ tickets for a store bought toy electric scooter. unreg vehical no plates no signal no insurance lots and it is messed up kids cant ride them even if their parents got it from the store
mmaciver says: Sep 28, 2012. 7:54 PM
Yeah, I was bored the other night, and went though all 50 states (and Puerto Rico) looking at the motorized bicycle/moped/scooter laws... NY state sucks in this regard; they will not even allow it in a parking lot! I'm sure there are places upstate that may be cool, but if they go by their laws... they really SUCK! I am so glad I don't live in that fu*^#%@ state!
rangerweavere says: May 19, 2012. 11:28 AM
No that would be you.
Once you hit 60cc's then its considered a moped.
mmaciver says: Sep 28, 2012. 8:01 PM
they don't go by "CC's" when talking about an electric propelled vehicle; CA law allows for no more than 1000 Watts power output, so he's WAY over!, and 30mph max speed, on flat, even terrain. He'd get a ticket for sure! In CA they may take his ride, and that would just suck! Most states have a limit of 25 to 30 mph, as a general rule. as far as engine size goes, for a motorized bike, some states accept up to 125cc (to allow for the Whizzer Motorbikes), while other's don't have a law for them, or electrics... check out www.moped2.org If you suffer from pain, like me, and have many hours awake in bed, you might be interested in reading about your state, or all of them!
woodstockbirdy says: May 20, 2012. 5:46 PM
Well, I guess I'm in Canada and they don't have to be registered, but I don't know in the US.
lloydrmc says: May 19, 2012. 10:55 PM
In my state it's 50cc and 30mph, if I recall correctly. I don't recall the regs on electrics. I have read that they go by speed, (either what it will do by itself, or the speed it assists you reaching if you are pedaling), and they are very strict.
mookiex4 says: May 11, 2012. 3:14 PM
Well actually in my State at least. If you leave the peddles and crank on it, they consider it still a bicycle and would be legal. Bicycles already have to obey the rules of the road just like cars. That means remaining under the speed limits and obeying all other traffic laws for the state. The only thing you wouldn't have to do is register it as a motor vehicle. If you look at most of the videos on youtube and such the bikes have digital speedometers on them.
lloydrmc says: May 7, 2012. 10:43 AM
Oh, please - "jail time"?
I agree.
Super Cronk says: Feb 26, 2012. 7:16 AM
It depends on the laws of your state. I know in North Carolina you don't have to register a bike that's under 50cc. However I don't know how electric bikes are covered there. You do raise a good point though. You want to make sure you know the laws where you live so you don't get yourself in trouble.
kbales says: Mar 9, 2012. 2:03 PM
For most US states the limit is 50cc and/or 2 bhp. So electrics would be limited to that 2 horse power range.
Many of those states also require that the top speed be either 30 or 40 mph but it looks like this thing may be doing better than that.
isaacwilk says: Jan 22, 2012. 3:46 PM
If you're not driving on roads you don't have to register anything.
woodstockbirdy says: May 19, 2012. 11:06 AM
Even if you were on roads you would not have to register it.
lloydrmc says: May 19, 2012. 10:56 PM
There's a specialized registration in my state for motorized bicycles.
AudioMaximus says: Jun 11, 2012. 8:01 AM
What would the legality of something like this be in NJ?
The MadScientist says: Apr 24, 2012. 6:38 AM
By the way nice bike.
AudioMaximus says: Apr 17, 2012. 8:05 PM
I think I just found my summer project...
My design however will have no welding, since I don't own welding aterials anyways. I'm thinking of using a motor from a lawn edger that I don't need anymore. i don't know if it will be enough horsepower (probably about 3-5 hp), but it's worth a shot. If it isn't I can always get a better one from a friend for a good price.
fmadwid says: Apr 1, 2012. 6:51 PM
Where can u get a rear sprocket with 66 teeth. Can't find that anywhere. I've everything else but that.
fmadwid says: Mar 30, 2012. 1:13 PM
I live in Canada, Ontario and can't find a Felt here. Does anyone have one willing to sell me?
geminitriplets says: Mar 25, 2012. 1:05 PM
Are the brakes sufficient for your bike? It seems that the increased weight and the speeds you can achieve might be too much for ordinary bicycle brakes.
hayme says: Feb 26, 2012. 8:09 AM
Well that sucks. in my country i cant buy parts like this. Is it possible to make some kind of a Tesla turbine placed on this? or if i can salvage some kind of a powerful fan engine or a boat engine, can i still put it in? what are the possibilities that if i did not follow your components, i am going to explode and burn?
Radioactive_Legos (author) says: Feb 26, 2012. 12:42 PM
I figure as long as you have a source of power that fits and that you can control, you should be safe(ish).  But always use your best judgement, and if you don't feel comfortable, don't do it.  Tesla turbine would be hard to adapt for use on something like this, though.  High RPM and low torque would have to be geared way down and you'd lose a lot of efficiency doing that.  Plus you'd have to supply some sort of fluid under pressure to keep it running.
hayme says: Mar 2, 2012. 2:03 AM
goddamn dude! when you said safe(ish) it feels like if i do it my way i am going to be like a taliban chopper with with paul bin hamad teutel sr. ok dude thanks for the advice and imma show you my stuff before i try to run this thing and hope for me not to go BOOM!
pie R []ed says: Feb 26, 2012. 6:51 PM
What's the range like on this?
1-40 of 362Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
