Step 1The Components
- Briggs and Stratton Etek motor (now discontinued)
- Alltrax AXE 300-amp programmable controller
- Magura 0-5K ohm twist-grip throttle
- 4 x 12V, 21Ah sealed lead acid batteries
- Avid BB7 mechanical disc brakes (160mm rotors)
- #35 moped chain
- 13-tooth drive sprocket
- 66-tooth rear sprocket
- big power switch
- 300-amp fuse
- 8 1/4 in. stainless steel motor mount (this replaces the original bottom bracket)
thanks
<http://www.marselectricllc.com/index.html>
http://www.allelectronics.com/make-a-store/item/DCM-160/24VDC-600W-MOTOR-15T-W/CLUTCH/1.html
is 450$ I don't understand how his total cost was $2500??
I kinda like this for being so cheap ($6!). They aren't very powerful, but you could put several of them on a friction drive (AWD?) and it would still be cheap enough to wire them in series to a bigger controller.
