48V Electric Flat Tracker
Step 4Rear Hub/Sprocket
Rear Hub/Sprocket
The rear hub we used is designed as a "dual disc" front hub. It has a standard mountain bike 6 bolt disc pattern on both sides. We took a blank 66 tooth rear sprocket and drilled it to accept the 6 bolt pattern. The alignment of the hub, sprocket, and disc rotor are critical.
6 comments
Jul 11, 2011. 1:52 AMpointlessmaster says:
I found some dual rotor hubs at this site:
http://www.choppersus.com/store/category/3/20/Hubs-Wheel-Parts/
Nov 17, 2009. 10:35 AMsifab says:
i would like to buy the rear hub? .. seems you could sell loads of them? what is wrong with you man are you stupid !! market the package !!!
Jan 18, 2009. 8:19 AMdex07 says:
I checked out your link Q5Quint, but those hubs are not what you want to use. Now i may be wrong but i think the hub he used here are a lot higher quality, aluminum and possibly sealed bearings. If your going to spend money on this thing don't skimp on the hubs, motor or brakes. I am also very interested in what these hubs here are as i can't locate them on the net either. -D
Feb 21, 2009. 5:50 AMdoccbones says:
hubs can be found at cycles US www.choppersus.com
Feb 8, 2009. 5:01 AMkevin.rants says:
I think they are Paul WHUBs - poke around MTBR.com, the Surly page and take a look at those with the Pugsley....
Jan 19, 2009. 4:57 PMTpb10505 says:
Ive looked all over for the same type of hub, but havent had any luck. I wish he'd clue us in on where he found it or had it made.
Jan 5, 2009. 7:49 PMdbc1218 says:
Where did you get that dual disk hub from? I've always thought it would be cool to have two rotors on the front of my bike but have never seen the parts like this. Do you know where I might find a dual disk fork as well?
Jan 14, 2009. 9:47 PMQ5Quint says:
http://www.choppersus.com/store/product/874/Front-Hub---Dual-Disc-CP/
dont know where to find a duel disk front hub~
-Q
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
108
Author:Radioactive_Legos
