Introduction: 4Duino UCAM-II Demo
Picture of 4Duino UCAM-II Demo
The main objective of this project is to show how to interface a uCAM-II serial camera to 4Duino. uCAM-II is a highly integrated micro serial camera which could be controlled by any host that requires a video camera or a JPEG compressed still camera for embedded imaging applications. uCAM-II processes various features making it trivial to interface to a microcontroller. Following are the list of few features to help you understand the module better.
  • 5V DC Supply nominal
  • On-board EEPROM providing a command based interface to external host
  • UART with 3.68Mbps for transferring JPEG still picture or RAW images.
  • On board VAG colour sensor and RAW/JPEG CODEC for different resolutionBuilt-in colour conversion circuits for 16-bit, 16-bit RGB, 8-bit Gray or standard JPEG images
  • No additional DRAM required
More information could be found from uCAM-II datasheet if required.
This project allows the user to capture images in JPEG format using uCAM-II and save it in a uSD card. The 4Duino’s resistive touch display is used as a means for a graphical interface to control and notify the status of the uCAM-II.
Step 1: How It Works
Picture of How It Works
Step 2: BUILD
Picture of BUILD
COMPONENTS
Build the circuit as shown in the diagram.
Step 3: Program
Picture of Program
Workshop 4 – 4Duino Extended Graphics environment is used to program this project.
This project requires the Arduino IDE to be installed as Workshop calls the Arduino IDE for compiling the Arduino sketches. The Arduino IDE however is not required to be opened or modified to program the 4Duino.
  • Download the project here.
  • Open this file using Workshop 4.
  • Connect the 4Duino to the PC using µUSB cable.
  • Then navigate to the Comms tab and select the Comms port to which the 4Duino connected.
  • Finally, go back to “Home” tab and now click on the “Comp’nLoad” button.
  • The Workshop 4 IDE will prompt you to insert a µSD card to the PC in order to save the widget images. Insert µSD card, select the appropriate drive and press button “OK”. If the µSD card has the widget images you can click button “No Thanks”.
  • After uploading the program in to the 4Duino, it will try to mount the µSD card. If the µSD card is not present it will prints an error message. All you need to do is insert the µSD card you saved the image files to into the 4Duino.
Step 4: DEMONSTRATION
Picture of DEMONSTRATION
Now you can easily a uCamII to capture and save JPEG images to your 4Duino projects.
The second photo is the image file captured by uCAM-II
For more creative stuff, visit 4Duino Projects.
Thank you !!!
ShadowPatriot90 (author)2016-09-07
I really hate how the music is playing throughout the entire video, makes it difficult to understand everything that is being said. But other than that, great instructable
About This Instructable
2,364views
21favorites
License:
Bio: 4D Makers is a group of curious engineers and enthusiasts who finds great satisfaction in creating and building anything from electronics.
More by 4D Makers:Universal Remote ControlBattery Checker3-Day Weather Forecast Feed
Add instructable to:
