4WD Obstacle Avoiding Robot - Arduino Smart Robot Car
Published
Introduction: 4WD Obstacle Avoiding Robot - Arduino Smart Robot Car
About: I`m 12 and I`m from Ukraine
Hi everyone. This my new project 4WD Obstacle Avoiding Smart Robot Car with Arduino Uno, Servo & HC-SR04.
This is a simple design robot you can easily build it.
Step 1: Requirements:
Project requirements:
Arduino uno R3
Ultrasonic Sensor HC-SR04
Servo Motor SG-90
Chassis 4WD with DC Motor and Wheel x4
9v Battery
Step 2: Wiring Diagram
Make Connections as in Wiring Diagram image above.
Step 3: Upload Robot Code
#include
#define TRIG 8
#define ECHO 9
#define IN_11 0 // L298N #1 in 1 motor Right Ahead
#define IN_12 1 // L298N #1 in 2 motor Right Ahead
#define IN_13 2 // L298N #1 in 3 motor Right Back
#define IN_14 3 // L298N #1 in 4 motor Right Back
#define IN_21 4 // L298N #2 in 1 motor Left Ahead
#define IN_22 5 // L298N #2 in 2 motor Left Ahead
#define IN_23 6 // L298N #2 in 3 motor Left Back
#define IN_24 7 // L298N #2 in 4 motor Left Back
Servo servo;
int angle = 90;
int lookLeft = 0;
int lookRight = 0;
int lookAhead = 0;
int timeEcho;
void setup()
servo.attach(10);
pinMode(TRIG, OUTPUT);
pinMode(ECHO, INPUT);
pinMode(IN_11, OUTPUT);
pinMode(IN_12, OUTPUT);
pinMode(IN_13, OUTPUT);
pinMode(IN_14, OUTPUT);
pinMode(IN_21, OUTPUT);
pinMode(IN_22, OUTPUT);
pinMode(IN_23, OUTPUT);
pinMode(IN_24, OUTPUT);
void goAhead(){
digitalWrite(IN_11, HIGH); digitalWrite(IN_12, LOW);
digitalWrite(IN_13, LOW); digitalWrite(IN_14, HIGH);
digitalWrite(IN_21, LOW); digitalWrite(IN_22, HIGH);
digitalWrite(IN_23, HIGH); digitalWrite(IN_24, LOW); }
void goBack(){
digitalWrite(IN_11, LOW); digitalWrite(IN_12, HIGH);
digitalWrite(IN_13, HIGH); digitalWrite(IN_14, LOW);
digitalWrite(IN_21, HIGH); digitalWrite(IN_22, LOW);
digitalWrite(IN_23, LOW); digitalWrite(IN_24, HIGH); }
void goRight(){
void goLeft(){
void stopRobot(){
digitalWrite(IN_11, LOW); digitalWrite(IN_12, LOW);
digitalWrite(IN_13, LOW); digitalWrite(IN_14, LOW);
digitalWrite(IN_21, LOW); digitalWrite(IN_22, LOW);
digitalWrite(IN_23, LOW); digitalWrite(IN_24, LOW); }
void distanceLeft(){ digitalWrite(TRIG, HIGH); delayMicroseconds(10); digitalWrite(TRIG, LOW); timeEcho = pulseIn(ECHO, HIGH); lookLeft = timeEcho/58;
void distanceAhead(){ digitalWrite(TRIG, HIGH); delayMicroseconds(10); digitalWrite(TRIG, LOW); timeEcho = pulseIn(ECHO, HIGH); lookAhead = timeEcho/58;
void distanceRight(){ digitalWrite(TRIG, HIGH); delayMicroseconds(10); digitalWrite(TRIG, LOW); timeEcho = pulseIn(ECHO, HIGH); lookRight = timeEcho/58; }
void loop(){
distanceAhead();
if(lookAhead<30){ stopRobot(); delay(1000); goBack(); delay(200); stopRobot(); delay(1000);
for(angle=90;angle>=10;angle--){ servo.write(angle); delay(5); }
distanceRight();
delay(100);
for(angle=10;angle<=170;angle++){ servo.write(angle); delay(5); }
distanceLeft();
delay(100);
for(angle=170;angle>=90;angle--){ servo.write(angle); delay(5); }
if(lookLeft < lookRight){ goRight(); delay(250); stopRobot(); }
else{
goLeft();
delay(250);
stopRobot();
else{ goAhead();
Step 4: Finish
That it once you upload code you are ready to go connect the robot with battery and play. I hope that you are all like my project
Thank you all!
    • Woodworking Contest
      Woodworking Contest
    • Microcontroller Contest
    • Make it Move Contest
    7 Comments
    Wow! Nicely done! What programming language did you use for the coding.
    Hi! Thanks.
    Arduino IDE.
    The Arduino IDE supports languages C & C++
    OK, Thanks! Keep up the great work!
