3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
4x4x4 LED cube
4x4x4 LED cube
I'm going to show you how to make a 4x4x4 led cube controlled by an arduino duemilanove.
PARTS:
arduino duemilanove
64 LEDS (color doesn't matter)
prototyping board
wire
100 ohm resistors (you need 16 of them)
soldering iron and solder
Step 1Making a template
Making a template
Get a piece of scrap wood and drill 16 evenly spaced holes into it. The spacing depends on the length of your LED leads. Drill the holes big enough to fit the LED into it. I used a piece of pegboard.
10 comments
Dec 30, 2011. 6:26 AMvishalapr says:
Nice ible :) But I have a question...I am using these LEDs...
http://www.ebay.pl/itm/110783289032?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_1456wt_1139
I have resistors of all the values from 1 ohm to 1 mega ohm....in 10's ....
So which resistors will I need to use for those LEDs? The cube is connected to an arduino nano...
plz help :)
Apr 9, 2011. 5:14 AMrtty21 says:
awesome inst'able
Apr 5, 2011. 8:06 PMMechonizer says:
Ok... Can you at least say were you copy pasted from?
First those images are from another instructible
http://www.instructables.com/id/LED-Cube-4x4x4/
Then the words In step 5 are directly copied with minor adjustments from
http://www.instructables.com/id/The-4x4x4-LED-cube-Arduino/
Seriously ... :(
Apr 6, 2011. 8:47 PMMechonizer says:
At least cite them or say were you got them from in the instructible because there is the cc copyright stuff saying you must aknowlage were you got it from...
Apr 2, 2011. 12:09 PMFaisal99 says:
hi electronic man
I have some qustions i hope to help me:
I made the all layers and i was build the cube
my qustions after i connect all wires to the board how i conect the board to the computer
second qustion which programe we shoude use to put the code on it.
last qustion if you can send the code via email because i cannt downloded
f-abo-saud@hotmail.
thanks
Mar 3, 2011. 6:29 AMrtty21 says:
Nice!
Mar 1, 2011. 10:23 PMzazenergy says:
LED cubes! Fun stuff.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:Electronics Man
My Motto: If it ain't broke, take it apart and fix it.
