3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
17 comments
May 3, 2012. 7:26 AMphlox01 says:
A friend and I made one of these when we were 15, back in the late seventies. We used silicon to seam the plexiglass and nuts and bolts to hold it in place. We also went to the local hardware and bought thirty feet of aquarium hose with the proper barb fitting and for a air supply line. We hooked the other end to a normal bicycle pump. We drilled holes around the bottom of the helmet to tie milk jugs full of mud to them. Four gallons of mud seemed to be the proper weight. We had a lot of fun using it in the local lake off the floating dock. We also hooked up a recovery rope to the helmet. We didn't strap it on to ourselves. We used an old garden hose to line the shoulder cutouts. Our helmet was an wet entry type, you had to swim underneath it to get into it. We took it down to about 25 ft.
Never made it to Phase Two which would have external lights on it.
Hope these memories give you some good ideas.
Apr 26, 2011. 6:36 PMmr.incredible says:
With out weight to off-set the buoyancy of the air in the helmet, you will only be strapped to a bobber. You will either need a huge weight belt (very uncomfortable) or weight strapped to the bottom of helmet. Here is another instructable for reference. http://www.instructables.com/id/Homemade-Diving-Apparatus/
For helmet material I'd go with transparent aluminum...
Apr 27, 2011. 7:39 PMLunera says:
I'm just gonna laugh, not at you mind. Okay yeah, at you, but I'm not being mean.
Transparent aluminum is a material from the rather fictional world of Star Trek. It was a plot device in the 5th movie, wherein Scotty(James Doohan) teaches a materials engineer how to make 'transparent aluminum' that was needed to have the strength of a sheet of glass 6 inches thick, but be only 2 inches thick.
Jun 8, 2011. 6:44 PMmr.incredible says:
Ha! It was a joke but check this out it is real! http://gajitz.com/science-you-so-crazy-transparent-aluminum-made-in-lab/
Apr 30, 2011. 12:55 PMtechno guy says:
You know, the last picture reminds me of those nuclear safe suit helmets.
Apr 26, 2011. 12:52 PMlemonie says:
I'd put more like 360o on the transparent-stuff, that will collapse a bit too easily I think.
L
Apr 26, 2011. 10:55 PMlemonie says:
Not really designed for actual diving then?
Make sure someone is there to pull you out if you need it.
L
Apr 26, 2011. 4:44 PMcaitlinsdad says:
You could have made the clear "porthole" viewer a double walled thin aquarium. Use silicone caulk and some rubber sealed toilet tank bolts to clamp on some pieces of acrylic. Fill the middle with some of that lava tank stuff with the floating object or a real marine environment. You can then pretend to take the kids to seaworld without paying the exhorbitant amusement park fee.
Can you get the bends if you get off of your easy chair real fast?
Apr 26, 2011. 5:11 PMcaitlinsdad says:
Haha, the bends is the common term for when nitrogen boils out of your blood when you come up too fast from deep sea diving or scuba, you need a decompression chamber to coax some of that back into the blood otherwise...
That's why there is no such thing as amateur deep sea diving as this would be a questionable way to start the hobby.
Apr 26, 2011. 7:05 PMcaitlinsdad says:
Hmmm, you might want to look at the comments on the linky from mr.incredible below. I guess if you are trying to replicate the conditons of being trapped in an air pocket in a sinking car, then by all means experiment with the lifeguard around.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:EngineerJakit(My YouTube Page)
Currently a college student in the most tolerable circle of Hell (Central Texas) working his way to be a machinist. Would love to build a mechanical awesome thing, like a mech or an anti-aircraft cann...
more »
