5 Gallon Flower Pot
Introduction: 5 Gallon Flower Pot
Thus instructable and came about as a result of boredom & necessity. At the urging of a friend, I made it my 1st Instructable posted.
I have a growing aloe plant in need of a larger pot. Since I didn't have one already, I started looking for a decent size one at the usual home stores. Nothing really stood out and since I like to diy & upcycle/recle, I came up with something easy, portable, & free.
Thanks for looking it over
Step 1: Materials
1- 5 gal. bucket
I chose the 5 gallon because the handle lays higher on the bucket and gives a deeper planter after the cut-away.
1- drill w/bit
drill bit size determines the drainage holes size.
1- jigsaw
it's much easier than a hack saw or utility knife.
-measuring tape
-stencils (optional)
-painter's tape (masking or duct work also but painter's comes off easier)
Step 2: Measuring & Marking
First things first...
Find where your handle lays on the bucket, measure up about 1 1/2 in. above it and that should be as far down as your cut-out goes. Any higher begins to reduce the view of the plants and just looks like a cut up bucket. Any lower reduces you plant bed.
Simply measure from the bottom up to the point above your resting handle and put a mark there. Do that around the rest of the bucket for your level line. Then tape it off all the way around using the marks to ensure a straight line. Draw out the design on the bucket with a sharpie (after scuffing & painting, it'll never be seen).
From this point you can scallop your cut lines for decor (I didn't bother). the strips going up to the handles can be straight, angled, wavy, etc. I did a slight angle for extra support.
Step 3: Cutting & Sanding
This is where the jigsaw is your friend.
cut in from the top and just follow your lines. If in doubt, cut a little wide then you can go back with another pass with the jigsaw or sandpaper.
Some might go at a slower saw speed so they can move slower, trust me... the faster the trigger speed, the easier the cut.
You've done your cut-aways with the jigsaw & used the sandpaper to smooth the edges. Next, do a light sanding and scuff along the outside, up the arms, and inside the edges & arms. It's not hard at all, it doesn't have to be sanded clean. this allows the primer/paint to stick.
Step 4: Painting & Finishing
Whatever color(s) you decide to go with, I'd suggest primer first, it'll help the paint adhere better. Because I'm using a white bucket, I did a black primer coat first, then went over it with a dark green which gave me a nice mottled look I wanted. I let it dry & did a couple matte clear coats over it to help it last outside.
I didn't paint the bottom, who's going to see it?
Don't forget to drill your drain holes in the bottom, the larger the bit, the more the drainage.
Step 5: Finished Product
Now my Aloe has growing room and I added some vine to soften it up a little more.
Also, you can use brighter colors or stencils for leaves, ivy, etc. for a better looking pot. Since I have no stencils readily available, I opted for something basic to blend with the plants. The white handle will be done by wrapping electrical or colored/pattern vinyl tape around it.
The whole project cost $0.00 and took up a little boring time between laundry loads & housework (about 1 1/2 total).
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    Thanks for the feedback. This was something I was needing but couldn't find any plans for so I made it up as I wen along. The next will have decorative scalloped edges as well as being painted yellow with green ivy & leaves stenciling. Id love to see any designs that other may come up with. Thanks again for the feedback!
    This looks great! Never would've expected this was made from a 5 gallon pail!
    This looks really nice!
