3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
$5 Macro Lens - for use above and below the waves
  • last photo ←
This is how to make a cheap macro lens for a camera which does not have a built-in macro feature. The one I am showing here is designed around a housing for my cheap underwater camera, but you can easily re-design this to fit whatever camera you'd like.
For those of you who don't know, the purpose of a macro lens is to allow your camera to take closeup photo's. Most cheap point-and-shoot cameras only let you get to within 1m or so of your subject. With the addition of a macro lens you can get much closer. A 2-3x magnifying lens will allow you to get within 10-15cm.
This project is quick, simple, can be put together for a few bucks, and only takes an hour to do!
I've made similar lenses to fit onto underwater video housings and an SLR housing. They all work fairly well. Unfortunately, I only took pics of the first, simplest lens I made. For you underwater SLR junkies out there, if you're using a flat port this is a way of getting a limited macro ability with a normal/wide-field lens. Unfortunately, it is not cross-compatible with dome ports.
A few note on lenses:
1) The lens you pick will have a huge effect on your final results. Generally speaking you want a 2x-4x lens; any less and you won't get enough magnification; any more and your working distance will be too short to be useful.
2) Glass is better than plastic, especially for underwater use. Glass is more durable, and less prone to scratching. Under water, both types of lenses will loose magnification (because the refractive index of water is not the same as in air), but the effect will be less for a glass lens.
Step 1What you need.
1. 2x to 4x magnifying lens. Glass is better than plastic. Lenses are not to hard to find - I "borrowed" mine from a dead microscope at work, but you can get yours from coin/stamp collecting shops (good lenses quality lenses are used for their inspection lenses - loupes I think they're called). Some hobby/science stores may sell loose lenses.
2. Sheet of thermoset plastic, 1/16 to 1/8 inch thickness. This should be available from most hobby stores.
3. Bottle, tube, or some other container the same approximate diameter as
the lens port on your housing (this is used as a mold). You need to boil this, so don't use your camera ;-)
4. Cyanoacrylate (instant/crazy) glue
5. Silicone glue
6. Short piece of cord (optional)
11 comments
Aug 7, 2010. 6:30 AMfarzadbayan says:
Nice !
Mar 15, 2010. 10:30 PMBroom says:
Well-done. Clever. Like.
Feb 28, 2010. 4:14 PMyeah i know says:
Nice... that's all I have to say. 5*
May 16, 2008. 8:42 PMjimihendrix4753 says:
Would a 1.5 magnifier work?
Jun 2, 2009. 10:26 AMjimihendrix4753 says:
Ok thank you.
Apr 14, 2008. 3:54 PMBig Ugly Mich says:
Good source for your lenses and other paraphernalia:
http://www.sciplus.com/category.cfm/subsection/21 (This leads right to the "Optics" section of their online catalog, since the need I'm addressing is for lenses).
Apr 12, 2008. 5:55 PMi make shooting things says:
great job i would love to see more pics
Apr 9, 2008. 7:03 PMstruckbyanarrow says:
sweat work +1 and you got my vote!
Apr 9, 2008. 6:35 PMBrennn10 says:
Excellent work! Great detail, nice work! Voted!
Apr 9, 2008. 4:44 PMGorillazMiko says:
I will do this most likely. I like the image of the snail thing. Very awesome Instructable. +1 rating.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Warthaug
I am a research scientist from Canada. My interests are broad - everything science, the outdoors, SCUBA diving, food, beer, etc.
