5 Min USB LED Light
Introduction: 5 Min USB LED Light
In this Instructable, I made a simple LED light than can be powered from a USB port.
What do you need:
  • 1 x LED
  • 1 x 100 ohm Resistor
  • 1 x USB cable (it does not matter what cable as long as it has a USB plug)
  • 1x Ping-Pong Ball
  • Hot glue
Step 1: Prepare the Plug
I cut off the plug and stripped the cables.
We need only red and a black cable. If there are 2 more cables, you can cut them off. They are used for the data.
Step 2: Solder the LED and Resistor to the USB Plug
To make sure the LED does not burn out when connected to a USB port, I soldered a 100 ohm resistor.
Step 3: Put It in the Ping-Pong Ball
I bent the LED, so it would take less space, then I glued it to the plug.
I cut a hole in a ping-pong ball and put it in the USB plug.
A drop of glue was applied, so the ball would not fall off.
That's it!
Simple USB light than can be powered from any USB port (As long as there is power)
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    this is very nice project. i like it.
    Using this project as base, you can use a longer USB cable (40 cm for example), an attach it some kind more rigid wire so you now have a directional light!
    I love all your projects because there so simple but extraordinary!
    awesome! Thank You so much
