3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
$5 Mini USB Fridge!
$5 Mini USB Fridge!
Now that we're seeing those 12 volt camper coolers turning up at garage sales and thrift stores (I found one for $2.50), here's a neat little idea for turning it into a customizable mini-fridge powered by a USB port!
Step 1Taking out the Peltier/Heatsink Unit
You'll basically just need a phillips head screwdriver and thin socket or needlenose pliers to take apart the heatsink and fans, which will allow you to remove the unit from the cooler. Now, you might ask why you'd want to do this and not just use the cooler. The answer is because most of the time when you find one of these the case will be cracked and the cord is missing, but that's not a problem...
448 comments
1-40 of 448next »
Apr 25, 2012. 11:36 AMilpug says:
I wonder if the same USB fridge unit could be hacked into an Xbox to cool it down....
Dec 5, 2011. 9:32 PMMatrix-technician says:
Great job! Very neatly done with good documentation. Just a note. Now they are selling $5 mini fridges on ebay that hold a soda can. I would recomend using it's unit as it is meant to run off of a 5v usb port, and it has a fan built into it. All you would have to do is make a "cooler" looking case for it. :p
Jul 27, 2011. 6:41 AMLangarulz says:
wouldn't it be better to put the heat sink at the top of the cooler?
Oct 30, 2011. 10:24 AMbluckie says:
no because it becomes less effective if not in contact with the bottle itself, another reason why cans get colder faster.
Sep 21, 2011. 7:51 AMnot_all_that says:
Hey guys. I'm planning to make this for my science project and I was wondering if anyone can explain some parts...
1.) where can I buy a cheap peltier cooling unit? or the 12V camper cooler (coz I really can't get how you stick that to the unit... explain please? sorry. I'm such a rookie...)
2.) how to make the fridge light up when you open it? (which is better lights when closed doors or lights when you open the door? please explain how to do this too)
3.) can this fridge be cool enough that the can (or bottle) be cold enough to drink lets say if you place a room temperature can inside? and can it be cool enough in less than 5 hours? (I read your comments to get insights)
Please help guys.... Thanks in advance! ♥♥♥
Sep 5, 2011. 12:13 PMzcbaker says:
Could this work for a mini soda dispenser that holds 6 12 oz pop cans?
Aug 20, 2011. 3:44 PMrab236 says:
Wouldn't it be more effective if the cooler was on the top, so it would cool all hot air rising up?
Jan 16, 2009. 7:07 AMroffenburger says:
If I were making this fridge, I would put the heatsinks at the top...cold air falls, hot air rises. I would think it would be more effective.
Aug 15, 2011. 12:55 PMfiredude20123 says:
for such a small area it will most likely make no difference
Dec 15, 2009. 2:38 PMendsgamer says:
 im making a project for geometry like this... im making a usb mini fridge out of a great rhombicuboctahedron 3d solid and since i feared it wasnt going to be cold enough i was going to do exactly that!
Mar 15, 2009. 11:52 AMjson12795 says:
what i would do is make another fridge on the other side of the heatsink which wouldn't really be a fridge but a toaster(kinda) that way hot air goes up cold air goes down.
Dec 15, 2009. 3:27 PMendsgamer says:
 but there is a fixed temperature differential with a peltier unit... if you capture the heat of the other side then it will heat up as will the cool side so that wont work... unfourtunatly, cool idea tho
Feb 24, 2009. 10:00 AMred-king says:
yep. but if you touch the top you'll burn yourself... lol
Aug 29, 2009. 4:14 PMdagenius says:
that's why there's a heatsink
Feb 25, 2009. 10:26 AMLew8 says:
use a low noise fan? lol
Mar 4, 2009. 6:18 PMctm53 says:
you should add the heatsink on the side and stick a fan on it
Mar 9, 2009. 12:24 AMklingoncowboy4 says:
keep in mind the current drain
5V is fine for powering a fan (well duh you can get USB powered fans comercially). I am not sure how much current a USB port can handle.
Too be safe I would buy a cheap USB Hub with its own power supply and power the "fridge" off of that. It may or may not be as reliable but since it is powered off the hubs power supply you won't fry the power on your computers usb. I have two notebooks that have fried power on their usb ports (data connectivity still works but you need external power on the device, such as a hub).
For temp control couldn't you build a switch with some resistors to regular the current going into the module? Also, for a desktop hack perhaps you could wire the module directly to the power supply on the computer by routing the cable through an expansion slot. Of coarse with that you might get two effects. Firstly you might end up with a freezer rather than a fridge, and two the heatsink will could get extreamly hot. In that case you would def need some additional cooling.
Thanks for this instructable it has given me some ideas. Such as building a custom case (perhaps using styrofoam as an insulator) and a brand new module. Such as this one http://store.qkits.com/moreinfo.cfm/QK66
Mar 9, 2009. 9:14 AMLew8 says:
please say you haven't bought that module yet? if you've got the time to build your own custom case (I know i haven't) buy a peltier from virtual village.com! ive got a 400watt one on its way that only cost 12 pounds! i'm guessing that if you want to make your own custom case your either a keen gamer or just want external power from the psu? if you just want external power from your psu you could adapt a spare pci slot on the case to be a dc power outlet? btw the max current that can be drawn from a usb is 100ma without request (there's no way to request 500ma other than through hardware, so don't even go there.
Jun 13, 2010. 1:13 AMminipancho94 says:
with a unit like that do you think i could make an actaul minifridge, like 2 by 3 size, hooked up to a socket of course, and any cheap but affective insulations i can use, was thinking foam baord on the outside with a wood frame and more foam board with insulation inbetween that.
Mar 9, 2009. 12:23 PMklingoncowboy4 says:
thanks for the link/info, no I havn't bought any of the parts yet, I just tought this project up as soon as I found this instructable, currently I have a limited budget and upgrading my harddrive is a bigger priority sorta a keen gamer, but mosty just like building electronics wanna get my advanced amateur radio licence so I can tinker with transmitters *evil grin*
Aug 1, 2011. 9:58 AMpolar bear6 says:
your favorite site is metacafe? even after they removed the kates playground movies? wtf man
Jul 20, 2011. 9:28 AMgmackenzie says:
Would i be able to do this but in a wooden drawer ?
Jun 15, 2010. 10:38 PMsuperMacaroni says:
Why is playstation and xbox a tag?
Jun 18, 2010. 12:14 PMfrankthehlytank says:
every videogame console these days has usb ports on them.. ill let you figure out the rest ;-)
Jul 1, 2011. 5:45 PMeramos fernandez says:
however, video game consoles require 110V and the 5V offered by a USB port isn´t enough. Also, would you be able to hook up your tv to the USB as well? it´s not very practical, but if you have other ideas please shoot :)
Jul 2, 2011. 12:11 AMstarver1 says:
Well, the figure it out yourself comment didn't work, so. Plug the mini fridge, into the USB port on your console. Didn't think the obvious needed pointing out, but then again, I've been wrong before.
Jul 1, 2011. 7:26 PMionic says:
Cool design!
Just a thought on efficiency. Since heat rises and cool air draws downwards, wouldn't it have been more efficient if you places the peltier device on top where the heat would flow up and away from the cooler surface and the cold side would coll downwards onto the bottle of water?? Basically a similar concept as placing your icepack on top of the goods you want to keep cool in a cooler.
Jul 1, 2011. 7:59 AMnorton220 says:
WOW! that's probably one of the coolest ideas i've seen in a while! i cant wait to find an old cooler and make one myself, so awesome. Good job and great attention to detail bro, keep up the good work!!
Jul 1, 2011. 5:47 AMElectronics Man says:
This is truly AWSOME! I love mini fridges and they are even better if they can run off 5v!
May 25, 2011. 6:42 AMprushik says:
This is badass! Seriously.
Although, I have one complaint, you are making a cooler out of another cooler. Although the one that you made was much more awesome than the original cooler.
I would suggest directing readers to a website online where they can purchase a Peltier cooling unit without needing to have an old cooler laying around. I found one on ebay, but there are also a few on amazon.
Jul 1, 2011. 4:39 AMilluminatis says:
they can also be found here
http://www.sciplus.com/category.cfm/subsection/16/category/155
Jul 1, 2011. 2:07 AMkretzlord says:
I know this has been up for a while, and perhaps this idea was already mentioned, but if you want a drink cooler, the best option is to go by conductive heat transfer rather than convective (sp?). If you put the cold side of the peltier unit sealed in the bottom of a waterproof container filled with a salt brine, you could cool drinks more efficiently, although the cans would be wet... just a thought
Jul 1, 2011. 12:13 AMdaggerofblood1243 says:
nice hand
Oct 26, 2010. 8:43 AMGanoderma says:
Hmm, I made one of these out of an old cooler and styrofoam.
At first I went for USB, it barely cooled the peltier.
So instead I now use 12V from an old computer power supply and I used the original double sided motor and fans to blow air over the big hot heatsink and the smaller cold heatsink.
However, it doesn't seem to cool very well. If I measured correctly, the temp drops 1C over an hour time. In the meantime the hot air coming from the hot heatsink is 5-10 degrees higher then the air in my room.
Did I do something wrong, is my peltier unit faulty or what?
Oct 26, 2010. 8:46 AMGanoderma says:
oh and I forgot to say, I put the unit on top of the room because cold air drops.
The air blown through the cold heatsink is recycled from inside the fridge itself so it's not like I'm constantly blowing warm air back in.
Apr 6, 2011. 5:52 AMznine says:
in my experience (after several trial & error) using two peltier inside a styrofoam box, it can dropped from 29 C degrees to 21 degrees after 5 hour straight.
still trying to dropping more degrees with some of fan inside and more encapsulation though. perhaps, next time i'll attach mine
May 18, 2011. 12:15 AMznine says:
this is mine (compact fridge or simple cool box, whatever since i didn't know to name it)
it can keep item inside being cold as long as not being opened. i power it with old power supply of computer (450w). still experimenting with the fan since it can dropped more degrees and make the inside more colder.
Thanks Babblin5 for the instructables. without it, i never create mine ^^
Feb 4, 2011. 7:13 AMpao_poopoo says:
is it possible to operate a mini fridge with a two 3volts rechargable batteri? will it be efficient???thanks for the immediate response
Jan 20, 2011. 6:07 AMbernhardus says:
is it possible to make a sligtly bigger fridge using more heatsink-peltier units? lets say quadruple the size it is in your project?
I would really like to make redbull fridge or something with this idea :P
Nov 1, 2010. 7:01 AMamazehehe says:
is there a peltier unit on the pc coolers? the ones with heatsinks
1-40 of 448next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
110
Author:babblin5
