Step 6The Final Result
iImage Information
As you can see by the pictures, this cooler will hold a large bottled water, or a tall 20 oz plastic soda bottle, although my drink of choice is a Starbucks Vanilla Frappucino! The cooler will keep drinks at about 45-50 degrees and works best when your drink is already cold for obvious reasons. Optionally, you could use a 1 amp 7.5 volt DC adapter, which will lower the temperature significantly without making the lower heatsink too hot for placement on regular surfaces. In this instance, I would strongly recommend that you add the 1K limiting resistor in order to keep the DC adapter from becoming hot.
http://www.radioshack.com/product/index.jsp?productId=2062343
Thanks for the great Instructable!!!
