Introduction: 5 Things We Learned in 1 Year About RockSolid
About: We're Mother Daughter Projects, sharing our DIY adventures as we learn to maintain, improve, decorate, and use tech in our homes.
There's a lot of interest in garage floor coatings—the appeal of which is the ease of cleaning and the fresh look it gives to the floor. But what to choose?
In January 2016, we used Rust-Oleum’s RockSolid floor coating in silver bullet metallic on Steph’s garage floor. RockSolid is an epoxy like product advertised has having superior quality and durability as well as being DIY friendly. One year later—how’s it holding up?
For full details, please visit our website.
Step 1: Watch the Video
Lets back up a bit and talk about the product being “DIY friendly.” Yes, the product is manageable to apply, but to get to the 'straight forward application part', you have to be sure the concrete floor is clean and ready.
Because Steph’s garage floor had been previously painted, it required quite a bit of prep work to get it to the point of being able to use the product.
Ideally, if your concrete floor is new and clean, application of the product should be straight forward. If not, be prepared for some work and even after all that work, there may still be a concrete issue that is not apparent.
Step 2: Slippery When Wet
The floor is slippery when wet, but really slippery when you get sawdust on it. We do woodworking projects in Steph’s garage, therefore we have sawdust spills. We have to be very diligent about keeping this swept up because it's definitely a slipping hazard. On the positive side, the coating makes it easy to clean up sawdust and other debris.
Because the garage floor is no longer absorbent, any water on the floor must be dried or squeeged out. If not, it travels to the sides of the garage where it pools and could potentially damage anything stored there.
Step 3: Scuffs and Scrapes
It does scratch easily and scuffs—both are cosmetic issues which so far have not been a problem. Be aware that if you drag something across the floor, it will probably scratch. It’s especially apparent where we move the trash can in and out. Also, dropped tools might leave a divot. This is not a real issue for us as this is a working garage and we would expect the flooring, regardless of type, to take a beating.
Step 4: Hot Tire Pickup
Unlike a lot of people, Steph actually parks her car in the garage. We noticed last May, that in certain places where she parked her car, the flooring had chipped and peeled. It continued to do so to a point that we contacted the company for advice late last month on how we could stop the problem and/or correct it.
Rust-Oleum did not have any clear answers as to why the problem was happening; only that perhaps the concrete in those areas was compromised or damaged when it was first poured.
Rust-Oleum’s help support suggested chipping off the coating around the peeling areas until we met resistance and couldn’t pull anymore off and then recoat those areas.
It was apparent that the coating had not adhered well in these areas, as the coating kept coming up with little effort. This resulted in some fairly large areas to repair.
For details on how to apply the product, please see our original video here. And don't forget to see how to prep the concrete floor here.
Recoating the damaged areas was pretty straight forward although we used a brush rather than the provided roller as it took too much off. We needed more of a puddle of coating to fill in the now lower areas. The brush worked well.
Step 5: Don't Use Outdoors
The instructions clearly state not to use the RockSolid coating outside, but we tried it on the small ledge right outside the garage door and sure enough, it broke down in the sun here in FL and washed away very quickly! Now, a year later, we are going to fix this by using a gray outdoor epoxy.
First we sanded the old coating.
We put down a piece of painters tape to get a nice straight line between the RockSolid coating and the outdoor Behr epoxy.
We also filled the crack between the garage floor and the driveway with a crack flex sealant.
Step 6: Clean Up Is a Breeze!
The smooth nature of the coating makes it easy to sweep or vacuum up debris or to squeegee out water. We’ve been very successful in getting up paint and more off the floor even after it has dried.
Overall, we wanted to post this one year update because our install video for this product is our most watched, at over 100,000 views. We wanted to continue to share our experience with it, so you have a clear picture of how the product works and holds up.
If you have any questions, please let us know in the comments below or feel free to email us.
