3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
5 Things to Do with Hot Steel, and Ideas for More.
Following the puzzlement on how I made the loop on my throwing knife instructable, I thought i'd make one on the things that can be done with hot steel. I've missed a few out because i think the basics are covered here. If you want to make a bar thinner, for example, you only need to use a slight variant on Drawing out the bar. If you try this a bit, you'll get the hang of it.
The only thing you have to know is that you're changing the profile of the bar, but leaving the volume the same. You can beat it out into foil, or forge it into a sphere, but it'll still be the same volume.
Step 1Upsetting Steel bars
  • G:\DCIM\100HP715\IM000846.JPG
  • G:\DCIM\100HP715\IM000847.JPG
  • G:\DCIM\100HP715\IM000848.JPG
Not upsetting as in "Making Steel bars Unhappy", but reducing the length of the bar and making its cross-section larger.
Heat the end of the bar, or the bit you want to be wider to forging heat. Place the bar end-down on the anvil and hit the top, like hammering in a nail. If it cools down too much, put it back in the fire until it gets hot again, then carry on. Upset the bar until it's at the desired thickness.
You can use Upsetting to put bulges into a bar, or to make rivets, nails, bolts, ETC
38 comments
Nov 9, 2010. 8:28 PMdrewgrey says:
Using a fuller is my favorite way to manipulate metal. I used one to make a hinge for my pizza oven.
Jul 31, 2009. 2:33 AMgearhead1951 says:
google , back yard metal casting and follow th' links ! there is a ton of info on furnacebuilding , forge work and , of course , metal casting !!
Apr 16, 2008. 4:28 PMUltraMagnus says:
so? where exactly can one buy a forge? or an anvil for that matter? i would imagine that its not something B&Q stock?
May 26, 2008. 10:40 PMRishnai says:
In order to be cost effective, you probably ought to make a forge, actually. I hear those things are awful expensive, but my homemade concrete and steel monstrosity works just fine for cheap. As for an anvil, I don't know where to get one, but I use an old railroad rail and a brake drum and it works just fine for the stuff I do. I got both of those at a scrapyard.
Apr 16, 2007. 1:08 AMjtobako says:
Punching, as in a hole without using a drill. Welding (not there yet, but trying). Looking good!
Apr 25, 2007. 4:53 AMironsmiter says:
if you really want to punch a hole, just to punch a hole.. I've got an easy tip for you. Goto the hardware store and get a masonry nail. heat your stock, and hammer a small flat spot. while it's still cherry red, clamp the work in your vice, grab the nail and a hammer, and drive the sucker in. Once it's through, you can rotate the work 180 degrees and gently tap the nail back out. Instant hole, with NO loss of material(except to scale, but that's normal ) Don't try this with a normal nail, as they are pretty darn soft, and can be bent in wood... much less metal. the masonry nails are hardened. Welding... not liable to happen on air/propane... For flux, Borax is hard to beat. it's cheap and readily available as laundry detergent(or is it dishsoap? can never remember. A single 5lb box has lasted me forever. Also useful as a flux for casting silver/bronze by the way)
Mar 28, 2008. 2:02 PMthoraxe says:
a large propane forge can weld, its an old rumor running around that says propane forges can't weld. This guy has such a super powerful forge, he can melt chromium (melting point 3000 degrees F) He makes his own stainless steel.
Mar 28, 2008. 10:21 PMironsmiter says:
True.. with a properly constructed forge, propane/air is perfectly capable of getting welding heats. "i'm not sure this little furnace gets enough heat" and he's using naturally drafted air supply, not forced air. I didn't mean to say it was not possible at all... just not with his setup. My old natural gas forge could melt cast iron in under an hour. but it used a TON of fuel, and had a large squirrel-cage blower, and at those temps, the refractory would sag, crack, crumble, and melt. Once I got the "good stuff", it got better, but even a copula furnace with highest grade refractory still sluffs and spalls at 3000+F. I'm pretty sure there's an instructable detailing how to make such a forge already posted. If i find it again, I'll link to it, for those wanting to do more than spot heat their steel.
Mar 29, 2008. 3:42 PMthoraxe says:
cool
Apr 14, 2007. 11:20 AMVertigo666 says:
i like that mini forge you have. So, how did you manage to bend it 360? just hammer it into shape?
Apr 14, 2007. 3:02 PMVertigo666 says:
instead of heating and pounding on an axe, can't you just take a hacksaw and cut the metal?
Apr 15, 2007. 11:37 AMVertigo666 says:
yes... but somewhat safer
Apr 16, 2007. 1:05 AMjtobako says:
So is buying a knife-or not owning one in the first place. Playing with fire and knowing you can get burned is like playing baseball-you know you can be beat, but it's still fun to play.
Apr 24, 2007. 3:01 PMAustringer says:
I don't think too many people say, "Hey, got to cut a 1/2 inch bar, time to fire up the forge!" Assuming you've got the forge going, walking away to go cut something has it's own risks.
Mar 7, 2008. 6:44 PMthoraxe says:
its easier with hot cutting >_>
Jan 26, 2008. 5:55 PMFunkNattidelic says:
is that tiny stainless steel ruler one that you got in a toolkit by workforce? i just recently got a toolkit by workforce and it had something that looked quite similar to that ruler in it...
Nov 4, 2007. 4:55 PMPunkguyta says:
How about 10 second tattoo's?
Nov 10, 2007. 1:14 PM!Andrew_Modder! says:
... LOL
Nov 10, 2007. 7:10 PMPunkguyta says:
Or we could shove you onto a spit made out of a glowing orange steel rod and cook you from the inside out, just like microwaves without the waves, Innovation!
Dec 23, 2007. 5:44 PM!Andrew_Modder! says:
ya, you forgot #6, to brand a cow :-D. LOL idk heh.
Dec 1, 2007. 11:17 PMpappyld04 says:
Where's the Smithy group. I must be discombobulated!!! Or is it the forge group?
Apr 23, 2007. 1:25 PMrplatter says:
If you want the twist to be consistant, you need to finish it in one heat. Otherwise it is almost impossible to get the twist to match.
Apr 15, 2007. 12:25 PMs666666666666 says:
i've taken a beginners black smith course and is it a really interesting hobby or way of life! i'm sure i could put in my 2cents and help someone out
Apr 14, 2007. 3:31 PMFerrite says:
Is anyone interested in a blacksmithing group?
Apr 14, 2007. 8:03 PMmeddler says:
I like the idea of a blacksmith group, i don't know much about it but i would like to.
Apr 14, 2007. 11:17 AMVertigo666 says:
a bit, a bit.
Apr 14, 2007. 10:27 AMWeissensteinburg says:
bigulation? lmao
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
52
Author:Vendigroth
I shouldn't have to tell you that using a dagger to undo this little, fiddly screw's a bad idea. AAAAARGH! big project ^^ so practically no chance of instructables from me till july, p'raps? maybe a...
more »
