3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
5 Tips To Beating A Cold
Cold and flu season is here, and sooner or later, you or someone you know will get it. Use these tips to speed your bodies natural healing qualities!
Step 1Drink More Liquids
Drink More Liquids
When you are sick your body produces more mucus. That's what makes you all stuffed up. When you increase the liquids you intake, it makes the mucus flow better causing you less problems.
Get a good herbal tea and sip on that. It will get more liquids into you and make your throat feel better.
5 comments
Mar 8, 2012. 8:45 AMartobot says:
Since there's been a couple deaths using a neti pot, it would be good to have this:
"If using a neti pot or other nasal irrigation device, use distilled or filtered water. Keeping the device clean is crucial, too, Ratard says. A neti pot, which looks like a small genie lamp, can be safely washed in a dishwasher, but squeeze bottles and other devices need to be scrubbed. All need to dry between uses. "If you let them dry completely, the amoebas are not going to survive long,"
source: http://www.npr.org/blogs/health/2011/12/19/143960631/second-neti-pot-death-from-amoeba-prompts-tap-water-warning
Mar 1, 2011. 10:12 PMffish says:
Nin Jiom Pei Pa Koa (ninjiom-hk.cwahi.net) may be another choice. i know alot of people use it, its also non alcoholic, though it's effectiveness is not as good as alcohol based cough medicine, but it's still good to use on not so serious scratchy throat.
Dec 19, 2010. 12:39 PMframistan says:
Very often, just before i get a cold, i noticed my throat feels "dry" or "scratchy." Especially at night while sleeping. Whenever I feel this dry throat , I gargle with a few drops or teaspoon of mouthwash.Then back to bed i go. Next morning the throat dryness is gone!... and cold averted! Sometimes.. about once a year... that method fails and the cold gets me. Once the cold gets me, I sleep with an electric blanket to get my body temperature up. Kind of like the American indians used to have "sweat-lodges" to sweat out the sickness. Doing the electric blanket I can almost always kill a cold in just a couple days. KEEPING warm... especially my feet... stops me getting "chilled" and so I DONT wakeup sneezing every half hour when staying warm with electric blanket! I believe the elevated body temperature simulates having a "fever" and the body defenses kick-in. I like your idea of taking zinc and vitamin c. I will try that also. Great instructable.
Dec 16, 2010. 5:06 AMnoglider says:
Good stuff! Thank you!
I've heard that we tend to want not to exercise when we have a cold but actually, it doesn't hurt and can help. I suppose it shouldn't be super-vigorous, but in any case, we shouldn't stop exercising just because we have a cold.
I have found that some strong foods such as hot peppers and raw garlic help. Take as much as you can tolerate. Push yourself to the limit taking these.
Most of these remedies and measures work best at the beginning of the cold. This goes for echinacea etc, too
Dec 16, 2010. 5:12 AMbowmaster says:
Anything that raises your heart rate a bit is good when you're sick. It helps push all that fluid and those vitamins around. Heck, just play some FPS's, those can get your heart going if your immersed enough.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
397
Author:frenzy
I'm the QA engineer here at instructables. I make cool projects in between testing instructables.com to make sure it works awesomely. Give me your bugs!
