5 Volt Regulator
24,700
47
9
Published
Introduction: 5 Volt Regulator
About: Love to make things / soldering / Arduino / Electronics / Nitro RC! / The Netherlands! / Love Music
Hi, this is a simple circuit for a 5 volt regulator with a input voltage from 8 to 12 volts.
just follow the circuit diagram and you"ll be fine.
(Sorry for the bad grammar, i`m from Holland)
                    ↑↑↑↑↑↑↑↑↑↑This is how your regulator could be looking like when you`re done :)  ↑↑↑↑↑↑↑↑↑↑
Step 1: Parts
The things you need:
1x TS7805 5 volt regulator
2x 1uf capacitor
1x power plug (or other connector)
1x 220 ohm resistor
1x Blue LED (I used a diffused one)
1x Mirco Switch
2x connector
*The LED, switch and two connectors are optional, make it how you want.
*You could even add a cooling van for higher voltages!
Follow the schematics  at the pictures and make sure it works on a breadbord if you have one before soldering it on a PCB.
Step 2: Using the Regulator
I use my regulator to power my breadboards!
    • Microcontroller Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    9 Comments
    Kan je mij uitleggen waarom de capacitors erbij zitten, ik heb deze schema's ook gezien zonder capacitors.
    Hi!
    I was wondering... what happens to the output voltage/current when the input voltage is 5v?
    You will be quite dissapointed if you follow the schematic.
    I see what`s wrong, the LED is placed wrong, it must be connected before the regulator :) Or isn't it?
    Yes, the led should be before the regulator.
    No, it, and it's resistor must go from + plus to - minus, as it does on the upper drawing (which is correct)).
    I see what you mean :) i will change it tomorrow, thank!s :)
    Very good, just what I was looking for
