3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Easy $5 Water Guns
Easy $5 Water Guns
Recently I found myself needing a whole bunch of water guns. I didn't want to spend a lot of money, and I wanted ones that would be durable and last a long time. I figured my best bet was to just make my own.
I began by looking at a few places online, and right here on instructables for some ideas. I found the water mortar (part one and part two), and the waterzooka instructables very helpful.
With the basic idea of a piston/barrel-type water gun in mind, I wandered around the hardware store for a while until I came up with the following design.
I made a lot of these, and individually the guns ended up costing around $5. It'll cost you more or less depending on a number of things, of course.
They are tons of fun, and we get them out on a regular basis for family water fights. Thanks for looking. I hope you find this useful!
Step 1Supplies
Conveniently, 1-inch PVC fits quite nicely inside 1 1/4-inch PVC. These sizes of PVC make up the barrel and piston sections of this water gun.
From one 10-foot length of PVC of each of the above mentioned sizes, you can make four 30-inch water guns or six 20-inch guns. The 30-inch guns are best for older kids and adults, whereas the 20-inch guns are easier for little kids to handle. Either way, the design is exactly the same.
This design is pretty simple and easy to mass produce. However, certain parts may be tricky to find. I had to check a couple of hardware stores before I found all the pieces to make this work.
In addition to the pipe, for each gun you will need the following:
  • One 1 1/4" PVC end cap
  • One 3/4" PVC plug
  • One 1 1/2" rubber washer, with inside diameter near 1/4" (and it must be real rubber, not neoprene)
  • One 1 1/4" fender washer, with inside diameter near 1/4"
  • One 1" by 1/2" 90-degree elbow, or similar (see below)
  • One 3/4" #12 pan head screw (or something similar that works)
I say "not neoprene" because common neoprene washers would not work for me. When I put pressure on the piston, water would just shoot out the back of the barrel. One of my local hardware stores carried real rubber washers which were a little stiffer than the neoprene ones, and these worked much better.
There are a couple of options for the 90-degree elbow, which will become the handle. I had plenty of 1/2" PVC scrap, so I got some 1" by 1/2" 90-degree elbows, and attached a small piece of 1/2" PVC to make the handle. You could use a regular elbow, or a cap instead, but I like the look and feel of the 1/2" handle.
38 comments
Jun 18, 2011. 6:54 AMBobMarleyFan says:
This one of the best things I've seen on instuctables! Hopefully if I can find the parts I'll make some this summer
Nov 9, 2010. 7:26 PMzoombaga says:
i guess i'll give you credit for this because you posted it first >:( but anyway I was having a water fight with some of my friends and I was running down a sidestreet, and unfortunately dropped my gun and broke it. After QQing for a couple minutes I thought to myself: "what would someone on instructables do?"
so then (still in instructables mode) grabbed the pump from the end of my broken premade watergun and found a small length of pvc in a neighbors recycling bin
(shh! don't tell anybody!!) but with the pipe and the pump handle i just needed an endcap... fortunately for me I constantly carry a credit card with duct tape rapped around it, using a pen ink cartridge as a mold I put about a half inch of duct tape around it with a piece of paper in the center (to make the duct tape not stick to the pen cartridge) i took the small duct tape roll with a hole in the center and put in the front of my pvc pipe with the help of some more duct tape and there you have it. an extremely ghetto water gun...
btw i only said duct tape 4 times and sorry for any grammatical errors
Aug 3, 2010. 4:02 PMsuperjoe12 says:
I did everything you said but I dont get how the finished piston is supposed to fit into the barrel with the 1 and 1/2 inch rubber washer being too big for the 1 and 1/4 inch pipe
Aug 4, 2010. 12:27 PMsuperjoe12 says:
This still doesn't work for me after using vaseline. The piston just wont fit into the barrel because the rubber washer is too big. Should I use a 1 and 1/4 inch rubber washer instead?
Jul 24, 2010. 6:47 AMpartymonsta says:
oh mines way to small. i was wondering why u shaved it. lol
Jul 23, 2010. 6:23 PMpartymonsta says:
my plug dosent fit snug it dosent even touch it. can u help or is that normal?
Jul 23, 2010. 7:52 PMpartymonsta says:
ok. but does yours fit tight?
Jul 16, 2010. 12:03 PMMeralis says:
Awesome tutorial! Can't wait to make these with my husband. Any ideas on painting them? I thought Camo would be fun but wondering if the paint would just come off on the user's hands.
Jul 20, 2010. 5:48 AMYandle says:
Check this out for a paint idea http://www.instructables.com/id/Water-Drop-Effect---custom-paint-secret-airbrush/
Jul 21, 2010. 5:33 PMclemsonguy1125 says:
For painting pvc, regular spray paint wont stck unless you coat with a plastic priming paint, you need krylon fusion(then he can enter it in the krylon contest too), sometimes regular paint will work if you coat it with a protectant but his best bet is to go with a plastic paint
Jul 21, 2010. 5:53 PMclemsonguy1125 says:
No problem, I had some issues when I was painting one of my potato guns, no matter what paint you use, make sure you sand the entire pipe to
Jul 15, 2010. 6:36 PMsolsed says:
how do you fill them quickly? is it a slow draw up through the nozzle or do you separate and fill and then reinsert the plunger?
Jul 15, 2010. 12:35 PMtuckerton296 says:
if you add a 1/2 inch pipeing on the end, its a vacume loading nerf gun. you can use yarn to seal it
Jul 15, 2010. 10:55 AMQuestor says:
just remember, people . . . It's all fun and games . . . until someone gets wet then the water balloon hand grenades come out and the next thing ya know it's escalated to garden hoses who KNOWS where it will end slipNslides . . .water wiggles
Jul 15, 2010. 10:15 AM99ottonero says:
wau!
Jul 15, 2010. 9:20 AMnoodliepoodlie says:
Awesome sauce with a side of cool beans!(bows down) i really bowed down! :P
Jul 15, 2010. 8:53 AMprofpat says:
this good for a summer project!
Jul 14, 2010. 12:23 PMdave367 says:
We've been doing these for years--both commercial and home made.
You don't really need the right angled handle; you're likely to brace the butt on your hip anyways (more range!), and if you push too hard on the right angle handle, it'll break. Saves a buck or two on the fitting, too.
Seals run the gamut, from rubber (as shown) to old-fashioned "leathers"--made of real greased leather (take apart a bike pump to see what I mean) to o-rings. O-rings are best, but require machining. You *can* do this by hand, with a small file. Chucking it in a drill and using a hand-held file works, too. We generally use 2" outer tubes, which, at 30" will hold about a quart of water. These are best used in pools or from boats, since the refills are nearer. ;-)
Capture The Flag is pretty fun, too. The "flags" are 5 gallon buckets--with trickling hose end inserted to keep 'em full--for filling the guns, of course!
If you get seriously fun, safety glasses are a nice thing, though if you hit them juuussst right, you can flip them off your opponent's face with the water stream. Harder to attack face/eyes if you wear a brimmed hat.
What I'm looking for now is a cheap and simple "laminar flow device" to increase range. In the meantime, chamfer, smooth and polish the "muzzle" hole to try to keep the water stream intact. If you make a bunch of guns, mark the ones with the best range, and make sure your "guests" get unmarked ones! ;-)
Jul 14, 2010. 2:12 PMdave367 says:
See: http://www.youtube.com/watch?v=OV-IazRk0sU Or if you're really interested, see: http://laminar.forumotion.com/ Dave
Jul 15, 2010. 4:07 AMLance Mt. says:
Would smoke-machines work in such a way?
Jul 14, 2010. 8:14 AMcucumber288 says:
you are so cool, make a cheap shotgun water gun too, that really cool
Jul 13, 2010. 10:14 PMMadBricoleur says:
Nerf gun makers and modders (like me) use 3/4 in PVC endcaps to fit inside 1 1/4 in pipe. It's not a snug fit, but just add some grooves around the endcap and hook on some appropriate o rings and attach it to a pushrod and voilà you got yourself a durable piston watergun. I'm pretty sure you can get more info about the endcap thing on nerfhaven. :) cool idea, at any rate!
Jul 13, 2010. 5:56 PMLeumasYrrep says:
I just made something very similar over this weekend that I am currently writing up the Instructable for. Yours are more friendly for the weekend DIYer as I had to use and engine lathe to build my piston. But with O-rings the ones that I made 2 years ago are still going strong.
Jul 13, 2010. 9:20 AMJohnJY says:
Nice job! I like the idea, you could even have "Backyard Wars"!
Jul 13, 2010. 10:57 AMJohnJY says:
Until someone decides they're going to act cooler then everyone else, and brings out the Super Soaker. Then starts spraying people in the eyes. So you have to get the hose to chase him of the lawn...
Jul 13, 2010. 7:04 PMsalomon1996 says:
to true....
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
465
Author:seamster
