3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
5 minute DNA Extraction in a Shot Glass
Despite its exotic-sounding name, DNA is ubiquitous - it can be found in every cell of every living thing and almost everywhere on the planet. Nonetheless, we rarely come face-to-face with the molecule itself - and it's not because DNA is difficult to find or isolate! In this instructable, we'll show you how to isolate your own DNA with little more than some dish soap, table salt, high-proof alcohol, a shot glass, and a bit of your own saliva.
It only takes a couple of minutes, and after you've isolated your own DNA, you can either drink it back down in a tasty "DNA shot" (great party trick) or better yet, purify it further for more analysis*.
Materials & Set Up
  • 1/4 of a shot glass full of your saliva
  • several drops of dish soap (look for sodium laurel sulfate in the ingredients)
  • a pinch of table salt (1/16 of a teaspoon)
  • some contact-lens cleaning solution, meat tenderizer, or pineapple juice (optional)
  • Ice-cold 120-proof+ liquor (overproof rum works well)
SAFETY NOTE:
The chemicals used in this experiment are "everyday" household items and are not particularly dangerous. Nonetheless, exercise extra caution and think twice if you decide to consume your DNA shot and ABSOLUTELY do not substitue rubbing alcohol, isopropyl alcohol, or any other non-consumable alcohol for the overproof rum we used. Besides using "denatured' alcohol, the other potential safety concern is the dishsoap added to the mixture. A couple drops won't hurt you, but if you are concerned about it, feel free to leave it out.
This instructable was produced by DIYbio - an organization for amateur biotechnologists. Visit diybio.org for more information.
EDIT: Some DIYbioers are developing a simple gel box and a gel box on steroids. We should have some instructables put together for them before Dec 08. If you are interested in helping, please join the DIYbio google group!
Step 1Salivation...GO!
Salivation...GO!
1/4 of a shot glass of saliva is harder to produce than you might think! Work your tongue against your cheeks and teeth as you think of a big juicy grilled steak / tofu cube / dim sum, or Muffins / baked cookies . I had to spit about 5 times to fill the glass 1/4th full.
If you are making the DNA shot for someone else, be sure to let them know where the DNA came from.
99 comments
1-40 of 99next »
Nov 15, 2011. 1:22 AMBroom says:
Any chance I'll get superpowers, if I expose the shot of DNA to some radiation? Maybe 10 seconds in the microwave...
Nov 14, 2011. 11:02 PMJuCo says:
not to be too crude, but the implications of "5 minute dna extraction in a shot glass" had me giggling for a moment.
Dec 26, 2008. 9:09 PMgogoplata says:
We did this in biology a few years ago with strawberries. Is there any way to do this and extract the DNA from white blood cells?
Nov 14, 2011. 10:58 PMOrganiks says:
A more important question is can you isolate white blood cells? That is far more difficult than ethanol precipitation
Feb 2, 2009. 10:30 AMShut Up Now says:
i did this with strawberries too. oh, and we used freezer cold methynol. we used a microscope to look at it after. we saw some double helixes.
Nov 14, 2011. 1:37 PMsdowney-forsythe says:
Um. BS. If you saw double helices, you were hallucinating.
Nov 14, 2011. 3:38 PMLithium Rain says:
Yeah, you need an electron microscope for those...
Mar 12, 2009. 12:22 PMste5442 says:
Wow - that must have been some microscope ;-)
PCBPolice
Dec 24, 2009. 11:30 PMShut Up Now says:
no, just a typical school grade light-microscope.
Feb 17, 2010. 8:32 PMEarths_hope says:
what grade? I did it in grade 5 with strawberries and used methalated spirits
Mar 11, 2009. 11:10 AMOldManMahoney says:
lol
Dec 27, 2008. 7:09 PMgahaga says:
There are no White blood cells in Strawberries :-) But if you want DNA from WBC's, you might consider following this protocol using puss from an acne lesion (a puss filled zit, or other source of puss) instead of spit. Otherwise, you'll need to get some blood, separate the Red blood cells (very easy really) and then you'll have mostly WBCs. It depends on how "purely WBC" the DNA needs to be. Why do you want to do this?
Dec 28, 2008. 10:01 AMgogoplata says:
I was just interested to see if this could be used for some amateur research or something. I think the DNA would need to be from only WBC.
Dec 28, 2008. 12:25 PMgahaga says:
MediaTech sells a product call Lymphocyte Separation mediumLymphocyte Separation medium (cat # 25-072-CI, 100 mL for <$20). That will do the trick, if you're starting with whole blood
Dec 29, 2008. 8:37 AMgogoplata says:
Thank you. I will look into that.
Aug 23, 2011. 5:32 AMjobard says:
Can I use Absinthe instead of overproof rum?
Nov 22, 2008. 5:10 AMjschroedl says:
Ew. cool project. Would there be anything interesting to see under a microscope?
Oct 24, 2009. 5:27 PMbears0 says:
 i dont think you can see dna under a microscope if you could it would have to magnify like one centillion time
oh and yes centillion is a number it has 330 zeros
thats a lot
Jun 14, 2011. 8:03 PMcrysisatutz says:
No, magnification of M=10^8 should be sufficient. Neutron scattering could do a good job for regarding DNA molecules.
Oct 26, 2009. 5:19 PMPlaid Demon says:
lol
Mar 27, 2011. 7:12 AMrocket master says:
If you chew your cheeks, you get more DNA.
Feb 20, 2011. 11:36 PMMcGrep says:
Fascinating. Why had I no idea this could be done so easily?
Feb 26, 2010. 8:54 AMchibibunny713 says:
 Hey - how long can these last for, What liquid can I preserve mine in (indefinitely), and How do you dye them?
Feb 17, 2010. 11:03 PMcheesekake22 says:
we did this in Project STEM and you can just swish salt water and it works fine.
Feb 7, 2010. 11:44 AMNitsuji says:
Canida is almost right. Pineapple, kiwi, and papaya all contain "proteases," enzymes that break-down proteins. However, each fruit contains a pretty different enzyme: pineapple has bromelain, kiwi has actinidin, figs have ficin, and papaya has papain.
Jan 28, 2010. 12:28 PMniwrad says:
hahaha nice trick! I did this with onions!!
Jan 8, 2010. 1:24 PMhamado says:
really nice..im going to try it right now
wish it works...
Dec 21, 2009. 1:56 PMCapnTac says:
What if you could clone yourself with it? That would be shweet.
Feb 2, 2009. 9:41 AMkid123 says:
you can do this with rubbing alcohol
Feb 23, 2009. 1:52 PMstonehenge360 says:
yes but drinking rubbing alcohol will kill you
Nov 23, 2009. 1:25 AMzhou777 says:
yes, but you don't have to drink it.
Oct 29, 2009. 4:56 PMnrepak says:
i dont know how much I would want to drink contacts lens solution considering what it does to the bowels
Oct 24, 2009. 5:13 PMbears0 says:
 we did that with spinach one time
Mar 15, 2009. 8:40 PMSlashDev says:
did you just drink dish washing detergent and/or meat tenderizer? bleah :P
Mar 15, 2009. 10:42 PMawang8 says:
Steak contains meat tenderizer...
Aug 17, 2009. 9:10 AMminime12358 says:
also, your plate must contain traces of dish washing detergent.....
Jul 18, 2009. 1:25 AMDrWeird117 says:
Hmm...What if...Nah.
Jul 10, 2009. 9:11 PMduckythescientist says:
If you are not consuming the shot, could isopropyl alcohol be substituted for the ethanol?
Jul 11, 2009. 8:51 AMduckythescientist says:
Never mind... I just answered my question with more research! It will work; I just won't drink it (I'm underage anyway).
Apr 12, 2009. 3:38 PMElectricUmbrella says:
Very, very intresting! Nicely done! You mentioned staining it - how?
1-40 of 99next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:macowell
I am passionate about amateur biotechnology and more generally what is called Citizen Science. After graduating with a degree in Biology from Davidson College, I worked at MIT coordinating the Intern...
more »
