Called a Motor Generator used to test equipment I occasionally design for England, Europe and Australia.
Remove these ads by
Signing UpStep 1MOTOR
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
As frequency goes up magnetic weight goes proportionally down.
WWII bombers and many military transports use 400 Hx (cycle).
Most of the younger crowd probably have never seen an MG cycle converter. Thanks for sharing.
A
The reason for the large converter set was that at that time there were 40 single channel transmitters at my base being powered. They were of the WWll tube type and the chassis were the size of footlockers. The radios were later upgraded to transistor types, then the power requirement was reduced, DRASTICALLY. The converter set was no longer needed as the power supplies of the new radios could be selected to run on 50, 60, or 400Hz, AC voltages from 90 - 265 vac. and also almost any DC configuration.
As you point out 50 through 400 Hz and 90 to 240+ VAC and sometimes DC if the device has input to that stage of the UpDownVerter.
Impressive techno world.
A
