Step 4Attach the legs
Make sure you assemble the legs BEFORE you attach them to the table. I neglected to do so on the first pair of legs and I think they came out a bit uneven. >_>
Anyway. Line up your legs dead center, mark the holes and drill away. Be sure as hell you don't go through the table. Screw the bases in then move to the second set. These are a bit tricky, as they want to bend towards the center of the table. I simply pushed them away from the center and marked the holes, then drilled and attached them. Do the same for the second set of legs.
When both legs are attached, open them up and flip the table around. Make sure everything is aligned properly and it lies flat.
We're almost done here...
Add Comment
